Combined brains of T-Bar needed!
Replied by amtcoupe on topic Combined brains of T-Bar needed!
Posted 11 years 10 months ago #96362
As above , check the simples first
Is the engine turning over
is there a spark
is there fuel
Posted 11 years 10 months ago #96365
whip the junction off the fuel filter and make sure its pumping juice (put a plastic tub in there to catch it ) , mine wasnt
Replied by groovylee on topic Combined brains of T-Bar needed!
Posted 11 years 10 months ago #96440
looks like i'm free John, we should have a mini meet at yours lol.
PM me your address if you still want another pair of hands / eyes? would be good to meet a few of you. can bring any manner of tools if required?
cheers,
Lee
Replied by mgfnortheast on topic Combined brains of T-Bar needed!
Posted 11 years 10 months ago #96460
I was talking with a guy yesterday and he told me about a TF problem he had. The remote opened the door with no alarm so he thought ok, but it wouldnt start. Went through the usuals no joy. As a last hope he opened the key fob and found 1 of the 3 prongs holding the battery had snapped off. Re soldered and started no probs. Worth a look. I should say if you do need to solder be careful of the size of the iron you use, you dont want to damage components with too much heat. Especially if its your only fob.
Last Edit:11 years 10 months ago by mgfnortheast
Last edit: 11 years 10 months ago by mgfnortheast.
The following user(s) said Thank You: David Aiketgate, KentJohn
Replied by David Aiketgate on topic Combined brains of T-Bar needed!
Posted 11 years 10 months ago #96464
Yes that can be another little quirk!:lol:
Posted 11 years 10 months ago #96467
Just added be careful of how much/long you apply heat as it can damage components.
  • KentJohn
  • Rediscovering driving
Replied by KentJohn on topic Combined brains of T-Bar needed!
Posted 11 years 10 months ago #96482
Thanks everyone and especially big thanks to Lee (Groovylee) and Paul (smithp25)! :broon: :hugs:
We checked for spark: check :broon:
We checked for fuel: check :broon:
We changed batteries: check :broon:
We changed spark plugs: check :broon:
We had a cuppa and a think :yesnod:
Still no sign of life - engine turning over - but no life! :-?
We checked that engine was actually turning by putting into gear and trying to start: check :broon:
We eased back the cam belt cover to check that it hadn't broken: check
We tried turning the engine over - and the cam belt didn't move :sick:
Russell - where are you :whistle:
OK we didn't mend it - recognised that this was a job for the professional, so Russell will be getting a call to do the job when he can fit me in. What we did do was logically work our way to a solution with the benefit of 3 brains rather than 1 going around in circles!!
Thanks Guys - you are stars :hugs:
John
The following user(s) said Thank You: Blow-in, groovylee
Posted 11 years 10 months ago #96487
That can only mean that the crank pulley is loose, I think.:shrug:
Last Edit:11 years 10 months ago by David Aiketgate
Last edit: 11 years 10 months ago by David Aiketgate.
  • KentJohn
Posted 11 years 10 months ago #96489
David Aiketgate wrote: That can only mean that the crank pulley is loose, I think.:shrug:
But it was turning the alternator :-?
Anyway - Russell now booked in for the end of this month (his earliest date) :woohoo: as this is beyond my amateur capabilities!!
Thanks again everyone for the support - really appreciated :hugs:
John
Posted 11 years 10 months ago #96508
Not a problem John. nice to meet you and Paul in the flesh, just a shame that it wasn't with some better news at the end.
As john says above, the crank pulley is turning, as the alternator belt was turning when the engine turned over. my thoughts would be one of the following:
1. tensioner has failed, and the crank pulley is not engaging the belt due to it being too slack
2. water pump has failed leading to the same symptoms as above, or
3. cambelt has failed near the crank pulley, and therefore isn't turning with the crank.
either way, not great, but at least we know what it is :pinch: :yesnod:
in other news, not wanting to be left out, my F overheated on the way home :nonod: and my windstop snapped :nonod:
will throw up another thread so i don't clog yours up John :broon:
Lee
Replied by benham on topic Combined brains of T-Bar needed!
Posted 11 years 10 months ago #96535
A man after my own heart, I spend much of my day getting annoyed with the "computer says xxx" or "computer says its all okay" attitude, OBD is useful as a guide, but it's no good for this sort of fault really!
A tip for all for possible starter motor faults:
Crank the engine with the lights turned on, if the lights dim then the starter is drawing current so it's either a charge fault or the starter is jammed.
If the lights don't dim, then it's most likely to be a wiring fault.
Regards,
Andy
by benham
  • KentJohn
Posted 11 years 10 months ago #96542
groovylee wrote: in other news, not wanting to be left out, my F overheated on the way home :nonod: and my windstop snapped :nonod:
Lee
Lee - sorry to hear that :omg: Hope no lasting damage (to engine - recognise the windstop may be beyond repair). I know you had plenty of oil in your boot :bust: hope you had some coolant too :broon:
Once again, many thanks for your help - really appreciated, and it was really good to meet up with you. :yesnod:
John
The following user(s) said Thank You: groovylee
Time to create page: 0.610 seconds
