Lost all my coolant
Lost all my coolant was created by Forrester
Posted 11 years 3 weeks ago #132712
Going to Gloucester this morning I became aware of a cloud of steam coming from the rear end & the temp. gauge nearly in the red :-? The low coolant alarm never triggered so I presume there's a problem with the float sticking. ;)
Pulled over & the header tank was empty & coolant dripping from around the rear of the engine.
AA man came & had a quick gander, but soon gave up & said it would have to go home on a B/D truck.
Arranged for Kayleighs lot to come & sort it next week.
Perhaps its getting it's own back for being hammered around Silverstone :dry:
Replied by Leigh Ping on topic Lost all my coolant
Posted 11 years 3 weeks ago #132714
Sorry to hear about that. :nonod:
The following user(s) said Thank You: Forrester
Replied by Cobber on topic Lost all my coolant
Posted 11 years 3 weeks ago #132716
Bugger! :(
What kind of coolant alarm?
Replied by Forrester on topic Lost all my coolant
Posted 11 years 3 weeks ago #132717
LoLarm, though a garage fitted it & I need to find cause of problem.
Posted 11 years 3 weeks ago #132719
It'd be good for those using the LoAlarm to learn of the cause of the failure so as they can keep a look out for theirs.
It'd be good for all of us to learn if the coolant loss was caused by anything that's not amongst the usual suspects.
Replied by bensewell on topic Lost all my coolant
Posted 11 years 3 weeks ago #132727
Sorry about your bad news. These lo alarms seem to be a bit rubbish at doing the job there supposed to
Replied by David Aiketgate on topic Lost all my coolant
Posted 11 years 3 weeks ago #132762
Very sad news, Roger. :hugs:
Hopefully just a leak, but with the temp gauge in the red...:shrug:
Replied by helsbyman on topic Lost all my coolant
Posted 11 years 3 weeks ago #132769
Yes , bad luck. new set of hoses perhaps :broon:
Posted 11 years 3 weeks ago #132838
Don't think it's HGF as the oil is clean.
What hoses are at the rear of the engine?
The rate of coolant loss points to something like a split hose.
Replied by Blow-in on topic Lost all my coolant
Posted 11 years 3 weeks ago #132842
Looking at the engine from the back of the car did the leak seem to be on the left or right of the engine?
by Blow-in
Posted 11 years 3 weeks ago #132853
The hose from the thermostat housing to the bottom of the expansion tank is vulnerable. :dry:
No. 9 in the diagram. No. 13 is another that fails often. (My last loss was this one.)
Last Edit:11 years 3 weeks ago by David Aiketgate
Last edit: 11 years 3 weeks ago by David Aiketgate.
Posted 11 years 3 weeks ago #132941
Looks like it could be hose no.4 in the diagram.
Looking from the rear, the coolant was dripping from slightly right of center, behind the engine.
Last Edit:11 years 3 weeks ago by Forrester
Last edit: 11 years 3 weeks ago by Forrester. Reason: wrong no.
Time to create page: 0.578 seconds
