She's stopped Flashing me (BROKEN LOOM)
- sherwood0_8
She's stopped Flashing me (BROKEN LOOM) was created by sherwood0_8
Posted 10 years 2 months ago #150780
Hello well no sooner than one problem is fixed another one crops up when locking the car I noticed my indicators have stopped flashing, now all signals are working central locking is working hazard lights work etc and car flashes it indicators when unlocked any ideas ????? has anyone come across this before ?????
Last Edit:10 years 2 months ago
by sherwood0_8
Last edit: 10 years 2 months ago by sherwood0_8.
Are you sure the car alarm is setting?
- sherwood0_8
The red led is flashing on the dash, but when I set the alarm I opened the boot no alarm but indicators flashed then when slamming the boot horn started going ???? I seem to be having lots of electrical gremlins after leaving her stand.
by sherwood0_8
- sherwood0_8
Really weird just been out to car with alarm set ,opened the boot with key lights flashed (no ALARM sounded) so opened the car with fob with boot still open closed boot relocked car now its all working ?????? do I have an intermittent fault or have I reset it ???
by sherwood0_8
I would suspect a dodgy wire in the boot hinge loom. :yesnod:
Normal alarm function should allow you to open the boot while the alarm is set. Closing the boot should trigger the indicators to flash to show the alarm is still set.
Sometimes a dodgy wire in that loom causes the alarm to sound when the boot is opened, so it does appear to be a similar fault.
by David Aiketgate
Last edit: 10 years 2 months ago by David Aiketgate.
- bryan young
David, my 09/96 mpi does not flash the indicators when closing the boot with alarm set, but flashing led on dash shows alarm has reset. I would put money on a broken wire in the boot loom or a bad earth on the gearbox to bulkhead earth connection.
by bryan young
- sherwood0_8
My alarm has always sounded when alarm has been set and boot opened with the key ever since I have owned the car ??? will have a look at the loom in the boot hinge
by sherwood0_8
- sherwood0_8
My double lock is working now too when I press the fob twice its double flashing
by sherwood0_8
Definitely a broken wire in the loom. :yesnod:
Probably more than one, tbh.
- sherwood0_8
so just open up loom have a look ??
by sherwood0_8
the wires get bent back and forward and eventually break. You can get all sorts of issues with wires cross connecting. Free the loom from the hinge and open it up. Be prepared for a lot of broken wires. I soldered in extra length on all the wires and ensured they wouldn't be bent at sharp angles.
The following user(s) said Thank You: sherwood0_8
Time to create page: 0.528 seconds
