Gunson Eezibleed Brake Clutch Bleeding Kit £10
- mgtfbluestreak
Replied by mgtfbluestreak on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172357Please Log in or Create an account to join the conversation.
Replied by jaypay on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172358Please Log in or Create an account to join the conversation.
- mgtfbluestreak
Posted 8 years 1 month ago #172360Please Log in or Create an account to join the conversation.
- mgtfbluestreak
Replied by G0RSQ on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172362Works fine on the clutch.
You will probably need to get an old cap and glue in a nipple for the eeziebleed.
Peter
Replied by Blow-in on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172363G0RSQ wrote: Sorry but the eeziebleed does not contain a cap for the TF/F brake reservoir!
Peter
Peter is right (of course). Don't buy the universal cap that Gibson's sell because it won't seal on the reservoir due to the underside sloping shape. In the end I bled my brakes using a non-return valve at the calliper.
Richard
Replied by David Aiketgate on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172365And for the Gunson's, it should be easy enough to pick up a brake reservoir cap at a scrappy and d.i.y a fitting into it.
Replied by talkingcars on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172371David Aiketgate wrote: .....And for the Gunson's, it should be easy enough to pick up a brake reservoir cap at a scrappy and d.i.y a fitting into it.
It is, I did.
Posted 8 years 1 month ago #172374David Aiketgate wrote:
That looks an interesting bit of kit. :yesnod: I'd be fascinated to hear any feedback on it.
If you think you need one of these, then it is probably time to replace the brake fluid anyway!
Peter
It is, I did.
Do you have a picture of your mod?
I need to do this before I need to use it on my brakes.
Peter
- mgtfbluestreak
