Gunson Eezibleed Brake Clutch Bleeding Kit £10
Replied by cjj on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172422
If you want to part with money, I can sell you a gravity bleed kit. ;)
If you don't, I can tell you it is free (if you already have a bleed tube) and gets better results than any of these kits.
Replied by mgtfbluestreak on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172423
yes a few mechanics have told me they just use the gravity technique..dindnt believe it at first....... :P
Replied by David Aiketgate on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172426
Of course, in Australia the gravity method results in all the fluid welling up out of the main reservoir... :dry:
But seriously, yeah I use the gravity method too, but I do sometimes help it along with a few pedal pumps and a pipe with an n.r.v. .in it.
Replied by Cobber on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172428
I use a vacuum pump to bleed the brakes, works much like gravity but shitloads quicker!
Posted 8 years 1 month ago #172430
I've tried the vacuum and wasn't as good for me.
Posted 8 years 1 month ago #172432
I have a one man bleed valve....which i like to use.......i like to see those pesky air bubbles leaving my fluid :P
Last Edit:8 years 1 month ago by mgtfbluestreak
Last edit: 8 years 1 month ago by mgtfbluestreak.
Time to create page: 2.461 seconds
