Gunson Eezibleed Brake Clutch Bleeding Kit £10
Replied by mgtfbluestreak on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172357
not sure if there is a cap in the set to fit our cars or not....
Last Edit:8 years 1 month ago by mgtfbluestreak
Last edit: 8 years 1 month ago by mgtfbluestreak.
Replied by jaypay on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172358
I hope it does ,because I just ordered one!
by jaypay
Posted 8 years 1 month ago #172360
Replied by G0RSQ on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172362
Sorry but the eeziebleed does not contain a cap for the TF/F brake reservoir!
Works fine on the clutch.
You will probably need to get an old cap and glue in a nipple for the eeziebleed.
Peter
by G0RSQ
Replied by Blow-in on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172363
G0RSQ wrote: Sorry but the eeziebleed does not contain a cap for the TF/F brake reservoir!
Peter
Peter is right (of course). Don't buy the universal cap that Gibson's sell because it won't seal on the reservoir due to the underside sloping shape. In the end I bled my brakes using a non-return valve at the calliper.
Richard
by Blow-in
Replied by David Aiketgate on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172365
That looks an interesting bit of kit. :yesnod: I'd be fascinated to hear any feedback on it.
And for the Gunson's, it should be easy enough to pick up a brake reservoir cap at a scrappy and d.i.y a fitting into it.
Last Edit:8 years 1 month ago by David Aiketgate
Last edit: 8 years 1 month ago by David Aiketgate.
Replied by talkingcars on topic Gunson Eezibleed Brake Clutch Bleeding Kit £10
Posted 8 years 1 month ago #172371
David Aiketgate wrote: .....And for the Gunson's, it should be easy enough to pick up a brake reservoir cap at a scrappy and d.i.y a fitting into it.
It is, I did. B)
Last Edit:8 years 1 month ago by talkingcars
Last edit: 8 years 1 month ago by talkingcars.
Posted 8 years 1 month ago #172374
If you think you need one of these, then it is probably time to replace the brake fluid anyway!
Peter
by G0RSQ
Posted 8 years 1 month ago #172375
It is, I did. B)
Do you have a picture of your mod?
I need to do this before I need to use it on my brakes.
Peter
Last Edit:8 years 1 month ago by G0RSQ
Last edit: 8 years 1 month ago by G0RSQ.
Time to create page: 4.414 seconds
