more power needed
- gotenks1321
Slippy;13806 wrote: :dunno: Cheap?:lmao:
Cant afford the supercharger route............is NOS expensive??
NOS is around the £7-800 mark with a bottle heater. Obviously you have the ongoing cost of filling the bottle too, I pay £5 per lb at the moment but it's due to increase soon...
Someone was selling new APs, discs and pads for £290 the other day.
FM :rolleyes:
WON systems seem to be favourite and you should factor in a progressive controller and bottle heater for the safest system.
- gotenks1321
FrankM83;13820 wrote: sorry if off topic but what sort of mods would be needed to install NOS? apart from the kit as I've heard it damages pistons?
You can add a 25 shot without any mods. It's recommended that you add a progressive controller and a grade colder spark plugs if you go up to a 50 shot, the controller basically means you can feed the NOS in rather than having it all dumped in at once. The TF 160 pistons are stronger than the F and I believe Debs is running a 75 shot without any engine problems, I think she was having traction or gearbox problems though
CJJ;13798 wrote: What sort of increases are you looking for?
This is only to make the car a bit more responsive, I've the T16 maestro for being nutty
I'm only looking for a bit, 15 or 20 bhp and resonably cheaply, maybe £2 or £300 and ideally with bolt on bits.
I have a '99 VVC so which version of MEMs will this have? Is it easily mapable.
- quicksilver
Its fairly straight forward just need to fit your existing injectors and sensors and its then a bolt on.Slippy;13794 wrote: Is the inlet manifold/plenium off a Mk2 Elise a straight swap job or is there anything else to it?
I have a VVC but its not MEMs3 so need to look elswhere for a bit more power.
- quicksilver
Some of the later model VVCs are MEM3 you need to have a look at the ECU if the sides of the unit are wedge shaped then its MEMS 3
If you can see HT leads at the back of the engine then it is a previous version with the coil packs below the inlet manifold.
