Is my clutch on the way out... :(
Is my clutch on the way out... :( was created by thatone1967
Posted 14 years 4 months ago #14264
Car is driving rather strangely at the moment, it feels like I am "riding the clutch"
Also revving at 3000 rpm when I am on the motorway @ 70... am I in for abig bill or just worried over nothing?
:rolleyes2:
2003 MGTF Monogram Edition. Celestial Blue, Black Leather.No. 19 of 99 Built 11 Spoke Alloys. AP brakes.
Replied by David Aiketgate on topic Is my clutch on the way out... :(
Posted 14 years 4 months ago #14265
thatone1967;14264 wrote: Car is driving rather strangely at the moment, it feels like I am "riding the clutch"
:rolleyes2:
To check your clutch:-
With the handbrake on full (If your handbrake is poor also press the brake pedal), switch on the engine, depress the clutch, engage 1st gear and slowly release the clutch.
The car should stall, if the clutch is dodgy you may be able to release the clutch a good way or even completely before it stalls.
If that happens check your clutch fluid level, and also check the movement of the clutch arm. If they're OK, You probably need a new clutch friction plate.
Replied by thatone1967 on topic Is my clutch on the way out... :(
Posted 14 years 4 months ago #14268
David Aiketgate;14265 wrote: To check your clutch:-
OK.. have tested this in first and second, call stalls in both cases, which is good... how do I check fluid levels? Looking at other sources on the net, it appears to being not as simple as checking under the bonnet....
Posted 14 years 4 months ago #14269
thatone1967;14268 wrote: OK.. have tested this in first and second, call stalls in both cases, which is good... how do I check fluid levels? Looking at other sources on the net, it appears to being not as simple as checking under the bonnet....
Checking the level is just looking under the bonnet...
You need two people to check the movement of the clutch arm, but I would suggest your clutch is OK.
Posted 14 years 4 months ago #14281
Checked it last night, need to top it up... very relieved... do I need a certain type... or is clutch fluid cluth fluid?
Posted 14 years 4 months ago #14284
thatone1967;14281 wrote: Checked it last night, need to top it up... very relieved... do I need a certain type... or is clutch fluid cluth fluid?
I use Dot 5.1 clutch/brake Fluid.
Posted 14 years 4 months ago #14288
David Aiketgate;14284 wrote: I use Dot 5.1 clutch/brake Fluid.
Thanks David, duly installed... felt better pretty much straight away!
Just need to wash the damn thing when it cools down a bit now...
Posted 14 years 4 months ago #14340
did not get around to washing the car... clutch fluid is looking good though... I topped it up on Saturday and having checked it, there are no signs of further loss.
Cheers Guys...
Posted 14 years 4 months ago #14753
clutch has gone... on hols..waiting for the RAC to take me home on the back of a tow truck.... a couple of positives, wont have to fill the car up to get home, and wont have to drive home either... on a more minus side... gotta get a new clutch...
Replied by Adam-Mgtf on topic Is my clutch on the way out... :(
Posted 14 years 4 months ago #14755
thatone1967;14753 wrote: clutch has gone... on hols..waiting for the RAC to take me home on the back of a tow truck.... a couple of positives, wont have to fill the car up to get home, and wont have to drive home either... on a more minus side... gotta get a new clutch...
where are you in the country mate? with the help of clive i did my clutch when it went saving £300+ of garage fees, may be able to help you out :)
Posted 14 years 4 months ago #14757
offer of help is much appreciated, but way south of you I'm afraid... car is currently in Devon, but with the help of the RAC, will be back home in Sandhurst near Camberley tonight...
Posted 14 years 4 months ago #14769
Bummer!:rolleyes2: Glad you've found an upside.:yesnod:
What was the actual failure symptoms?
Time to create page: 0.559 seconds
