Speed Pulse on Mk1
  • Visitor
  • Visitor
Speed Pulse on Mk1 was created by a Guest
Posted 14 years 1 month ago #16479
I'm thinking of upgrading my stereo to a SatNav version.
It appears that for it to work correctly I need to make a connection to input the speed pulse.
Does anyone know if the Mark 1 F has this facility and, if so, where is the best place to access the wire?
Thanks.
Replied by David Aiketgate on topic Speed Pulse on Mk1
Posted 14 years 1 month ago #16480
laz1957;16479 wrote: I'm thinking of upgrading my stereo to a SatNav version.
Thanks.
I think you would need a Mk2 to get an electronic speed signal.:dunno:
Why would sat nav need this anyway?
Replied by cjj on topic Speed Pulse on Mk1
Posted 14 years 1 month ago #16487
It extrapolates your position based on your last known position and direction should you lose the satellite signals going through a tunnel etc.
The power steering must still get a speed signal, so I thought there must be a sender in the dash somewhere.
Dieters site shows a WB cable (White Black) and it says Mk1, but it looks supiciously like a MEMs3. http://www.mgfcar.de/schedules/sb14.jpg
Replied by talkingcars on topic Speed Pulse on Mk1
Posted 14 years 1 month ago #16495
Doesn't the ABS send a pulse?
I do know someone who used a bicycle speedo to generate a pulse for his emerald ECU on his T16 maestro, I think he mounted it on an inner hub or a drive shaft.
  • Visitor
  • Visitor
Replied by a Guest on topic Speed Pulse on Mk1
Posted 14 years 1 month ago #16496
The Mk1 doesn't have ABS - I've got forearms like Arnold whatshisname :)
Replied by teri on topic Speed Pulse on Mk1
Posted 14 years 1 month ago #16500
laz1957;16496 wrote: The Mk1 doesn't have ABS - I've got forearms like Arnold whatshisname :)
Some Mk1's do have ABS, it was an optional extra
Angel to Devil in 0.2 seconds...[SIGPIC][/SIGPIC]
David Aiketgate;17095 wrote: Oi, stop using foul language or I'll give you one!
by teri
Replied by andycolm on topic Speed Pulse on Mk1
Posted 14 years 1 month ago #16506
My Mk1 has ABS..... The pulse from the speedo for the PAS comes from a reed switch in the back of the speedo operated by the cable turning I seem to think.... As the PAS switches off after a few minutes when the speedo cable snaps.
Posted 14 years 1 month ago #16507
ABS is a braking system.
PAS is power steering.
EPAS is Electronic Power Assisted Steering.:yesnod:
  • Visitor
  • Visitor
Posted 14 years 1 month ago #16511
Well I don't think I have either ABS or PAS on my '97 Mk 1
Whats this 'reed' thing then?
Posted 14 years 1 month ago #16512
Beryl my Mk1 has both ABS and PAS, but as I said they where optional extras..
The Reed jobby, I am not sure about sorry :(
by teri
Replied by bryan young on topic Speed Pulse on Mk1
Posted 14 years 1 month ago #16514
I have ABS and PAS on my Mark 1 and its a 1996 1.8 Mpi :)
Posted 14 years 1 month ago #16517
CJJ;16487 wrote: It extrapolates your position based on your last known position and direction should you lose the satellite signals going through a tunnel etc.
Ok. I think my Tomtom seems to do that anyway.:dunno;
Time to create page: 0.521 seconds
