Speed Pulse on Mk1
laz1957;16511 wrote: Well I don't think I have either ABS or PAS on my '97 Mk 1
Whats this 'reed' thing then?
To see if yours has ABS, open the bonnet and on the left hand side looking in there will/should/could be a silver box looking thing, with pipes going to it...
Angel to Devil in 0.2 seconds...[SIGPIC][/SIGPIC]
David Aiketgate;17095 wrote: Oi, stop using foul language or I'll give you one!
That's the technical term, of course!:yesnod::lol:Teri;16518 wrote: To see if yours has ABS, open the bonnet and on the left hand side looking in there will/should/could be a silver box looking thing, with pipes going to it...
David Aiketgate;16520 wrote: That's the technical term, of course!:yesnod::lol:
Of course David, you should have known that...... Was the easiest way I could think of to describe it
laz1957;16496 wrote: The Mk1 doesn't have ABS - I've got forearms like Arnold whatshisname
Shouldn't that be legs....................
My MK1 does, the warning light keeps coming on because a rear caliper is sticking.
- a Guest
- Visitor
So any ideas how I get a speed pulse please?
- a Guest
- Visitor
I don't know if these would be fitted but, if this is the right part, gettin one from a breakers would be easy - ther's 30+ auctions on eBay.
Does this sound right? :confused:
laz1957;16511 wrote: Whats this 'reed' thing then?
A reed switch is one triggered, either opened or closed, by a magnet.
They are common in building alarm systems or where a moving object needs to trigger a signal.
I very much doubt most of the wiring will be there for ABS on a non ABS model but if the F used wheel sensors I expect there will be most of the mounting hard wear.
Do you know if the feed to the unit has any voltage, if so you could use a reed switch mounted near one of the hubs with a suitable trigger on the hub.
The rings on the wheels for ABS are more slip sensors than speed pulse sensors, as they detect when a wheel is going slower than the rest of the car.
I'm sure you can buy aftermarket speed sensors if you don't have one fitted.
This might be of interest too
http://ecomodder.com/forum/showthread.php/fabricating-vss-13293.html
Geek!:yesnod:CJJ;16537 wrote: I would say a hall effect sensor picking up a pulse from a neobidium magnet superglued to one of the halfshafts would do it.
David Aiketgate;16551 wrote: Geek!:yesnod:
Errr, electrical technician if you don't mind.
