I need some exhaust reducing ideas
- rough luck
- Site Sponsor
- Jon
with this in mind, I have two exhausts that I have to switch between for track use as the TT is over 105db's
The TT with quads has to come off and the daytona with the fibreglass baffling removed goes on
In all honesty its a bit of a pain, as my back end has to come off too
So I've had a look at ways of reducing the outlets or blanking two off with bolt on/off bits has anyone got any ideas??????
Replied by David Aiketgate on topic Re: I need some exhaust reducing ideas
Posted 14 years 2 days ago #19063David
Posted 14 years 2 days ago #19064David
Posted 14 years 2 days ago #19065David
Posted 14 years 2 days ago #19066David
- rough luck
- Site Sponsor
- Jon
Replied by rough luck on topic Re: I need some exhaust reducing ideas
Posted 14 years 2 days ago #19069As it is now I have two 60mm pipes on each side, the ends of the tails are rolled back in to give the smooth finish,
I don't want to damage them so this is the idea
two discs of metal plate cut slightly smaller than the internal diameter, but bigger than the rolled edge
then cut the centre out about 40mm, so it leaves a 10mm (thickness of the outer band) washer looking type thing, cut totally through one edge so it can be pulled apart like a bit of a spiral, take two small nut/bolts only need to be about 10mm and weld the nut to the plate so that when the bolts are tightened they extend past the outer edge of the spiral washer, the nuts only need putting on one plate
take a length of 40mm pipe about 100mm long, slot the pipe through the big washers one on either end, weld them in place with a slight spiral, remember to put the nuts on an out edge
The pipe should now be able to fit in tail pipe by twisting using the spiral, once in it shouldn't come out without twisting and can be locked in place with the two bolts tightened against the outer edge
What do you reckon???
Posted 14 years 2 days ago #19070rough luck wrote: Ha ha The CAT is Still on already!!!!!!!!..lol
That sounds like it might do the business. Blue Peter rools OK?
Can you mock something up beforehand to see if you get sufficient noise reduction?
- rough luck
- Site Sponsor
- Jon
Yeah I could but have to finish the loo roll first....lolol
Replied by Ozzy on topic Re: I need some exhaust reducing ideas
Posted 13 years 11 months ago #19199fine for airfield days but may need more silencing if Mrs Oz decides to start tracking it...
Posted 13 years 11 months ago #19204Ozzy wrote: mines got a TT, and a standard cat... its between 107 and 109db at 4500rpm (depending on air temp)... !!!
I knew those things were too loud!:evil:
- rough luck
- Site Sponsor
- Jon
Posted 13 years 11 months ago #19208but mine still hit 106.6 and stood side by side I can easy drowd out a standard TT
ZT V8's can in at 114
How about a butterfly valve in each pipe. You could even have actuators and a selector on the dashboard to select the noise level. You know how much you like buttons and actuators.
