Engine Probs any help you can give??
Engine Probs any help you can give?? was created by rough luck
Posted 13 years 9 months ago #21100
Hi all
For those who know me I'm ok with engines BUT!!
Right late last year I blew the number 1 piston so Russell rebuilt the engine, this is what he did
replaced the old head with a spare that I had in the shed (the new one had 2 bent valves) the valves from the blown head went in to the new spare head
New piston, rings and conrod with new shells
What had caused it was a combo of the ecu packing up at the same time I was running Nos down the A1 and melted a piston
With the rebuild I replaced the ECU with an Emerald,
RIGHT TO THE PROBLEM:
The ECU is just about set up correctly now
The car has the normal VVC tractor noise on tickover, but now has a more high pitched tapping on top of the usual
This tapping happens up to 2000rpm then disappears either that or sometimes just goes on its own even below 2000rpm, I'm thinking its the lifters on the cams sticking with it being in my shed for so long, I'm I rite with this?????????
Second problem only over 5000 rpm it seems to burn oil, with black soot on the tail pipes and you can smell it in the car, so could this be related to the lifters or stem seals
I've put some winns oil flush in to see if it helps an it has a little with the tapping but not sure on the oil as don't want to rev it too high with it in
But if it is the stem seals can I replace them without taking the head off?????????
any other thoughts would be helpfull as I have to fix this one on a budget of near zero
Replied by David Aiketgate on topic Re: Engine Probs any help you can give??
Posted 13 years 9 months ago #21102
Did you replace all the shell bearings or just on the new piston? You can get a high tapping if a big end is starting to go but usually the low thump noise. The tapping could be a hydraulic lifter esp. if the head has sat for a long time
Oil through the stem seals usually shows on the over-run. you might need someone to follow you to tell if you're getting burnt oil at that point.
If it is stem seals Wynns/redex will make the smoking problem worse, as it cleans the stems and leaves a bigger gap for oil to escape.
You can replace stem seals in situ. You need a piece of kit to hold the valve in place from the top as you remove the collets/compress the spring etc.
Replied by rough luck on topic Re: Engine Probs any help you can give??
Posted 13 years 9 months ago #21103
Yeah it is very blue smokey on the over run, I can see it in my mirrors...lol
in that case I have a new set from a K-series 1.4 would the seals be the same??
O yeah only replaced the shell on the one conrod we replaced and were matched up with the code on the rod and the crank
Last Edit:13 years 9 months ago by rough luck
Last edit: 13 years 9 months ago by rough luck.
Posted 13 years 9 months ago #21104
rough luck wrote: Yeah it is very blue smokey on the over run, I can see it in my mirrors...lol
Sounds like stem seals then. Don't know if 1.4 K stems are the same.:shrug:
Posted 13 years 9 months ago #21105
I just checked my stash, they were in the bag full of good stuff I chucked out by mistake
Ebay they are only £8 an £2.50 delivery
I can clean up the lifters from the old knackered head too
suppose I should put a new cam belt on again, Hmmmm I had a new one in the same bag I chucked
Posted 13 years 9 months ago #21106
Only thing is what type of valve compressor will fit if the heads still on, the ones I've used before go rite round to the valve face
Posted 13 years 9 months ago #21110
The kit I saw used was a combined spring compressor and valve anchor. The kit clamped the top of the stem then part screwed down to compress the spring.
Sorry, I can't remember any specifics as it was a number of years ago I saw it being used. :shrug:
Posted 13 years 9 months ago #21112
I'm having a good guess an does it look like this
Valve Spring Compressor OHV Sealey VS160 Compression
Completed
that didnt work
http://cgi.ebay.co.uk/Valve-Spring-Compressor-OHV-Sealey-VS160-Compression-/400186606627?pt=LH_DefaultDomain_3&hash=item5d2cfb0423
Edit: Just needs the Item ID, Si
Last edit: 13 years 9 months ago by psymon.
Posted 13 years 9 months ago #21115
That's it exactly!
Clever bit of kit that saves a helluva lot of time and money.:yesnod:
Last Edit:13 years 9 months ago by David Aiketgate
Last edit: 13 years 9 months ago by David Aiketgate.
Posted 13 years 9 months ago #21116
says I'd need a compressor attachment, I take it they mean like an air line in to the spark plug hole to keep pushing against the valve
Posted 13 years 9 months ago #21117
rough luck wrote: says I'd need a compressor attachment, I take it they mean like an air line in to the spark plug hole to keep pushing against the valve
Yep.:yesnod:
Replied by bryan young on topic Re: Engine Probs any help you can give??
Posted 13 years 9 months ago #21119
Yes, its Sealey Part Number VS1601 :whistle:
Time to create page: 1.543 seconds
