steptronic gearbox removal ?
Just as I was starting to enjoy the mgf it decided to have a bang and a clonk,oil everwhere and I am left with a holed steptronic gearbox.the hole is in the diff caseing.Anyway what I need help with is the gearbox removal procedure,has anyone been brave enough to DIY it.I can't afford to let the garage do it so am having a go.Gonna source a second hand gearbox.
Thanks in advance Andy
Angel to Devil in 0.2 seconds...[SIGPIC][/SIGPIC]
David Aiketgate;17095 wrote: Oi, stop using foul language or I'll give you one!
David and CJJ are the guys who will be able to give you the best advice (I think) ..
Will take some pics too.......best tidy the garage first lol
Replied by David Aiketgate on topic Re: steptronic gearbox removal ?
Posted 13 years 8 months ago #21910I hope you've got some penetrating oil on the subframe bolts.:lol:andyjem wrote: Exhaust is all off,wheel hubs and drive shafts out,gonna drop the subframe tomorrow and remove the broken gearbox.
- rough luck
- Site Sponsor
- Jon
If you haven't its a real pain, you need the from of the car in the air on ramp at least, if you don't when you lift the back up the front will hit the floor before its high enough to get the sub frame out
Once its out its an easy enough job to swap the box over,
Things to watch out for if its an F is you'll need to get the hyrogas fluid out and have a pump to get it back up
Other than that be prepared for every thing to be stuck an everything needs disconnecting
- rough luck
- Site Sponsor
- Jon
Had the front wheels balanced on building blocks stood on their edge and and engine crane just tied to the back with a strap...lol
Watch out for all your electric sockets i.e. ECU and the relays behind it, one of mine just had a dodgey connection when put back together, everything still worked all dash lights the lot, but it just wouldn't start, one extra push of a socket an it fired first time
.All disconected and drained,hope to get the subframe lowered this eve if i get time.
I will keep an eye on those connections if I ever get it back together lol.....
Thanks again for your help .
- bryan young
Replied by bryan young on topic Re: steptronic gearbox removal ?
Posted 13 years 8 months ago #21927andyjem wrote: I'm doing it a small garage,it's a bit of a squeeze.,i didn't trust the weather to do it outside
Good luck and be careful :pinch: Check, check and check again that everything is disconnected before dropping the subframe. please keep us informed of progress, some pics would be good if possible :woohoo:
