Change Speedo Head Cluster from MK1 to MK2
Change Speedo Head Cluster from MK1 to MK2 was created by Schoppi
Posted 13 years 6 months ago #24064
Hello I am new on this MGF forum , but got aware that here are a lot of specialists which probably can help me.
I would like to exchange the speedo head cluster from my MGF MK1 (mechanical speedometer) to the once from the MK2 (with the digital speedometer). I bought the MK2 unit including the cables from the cluster to the plug point behind the dashboard. I also have the impulse sensor which will be fixed at the gear box (3 cables).
To get a better understanding about the differences I compared the colors of the plug wires and also study the wire schematics. At the connectors I found some minor deviations.
Is there someone who did this exchange before or can someone give me some hints what I have to consider?
Must I exchange other parts as well?
Before I start working I would like to have a cle
ar view.
Many thanks in advance. :thumbsup:
File Attachment:
File Name: PlugsMK1MK2.pdf
File Size:142 KB
Schoppi; a German who lives in Austria at the Bodensee.
Last Edit:13 years 6 months ago by Schoppi
Last edit: 13 years 6 months ago by David Aiketgate.
Replied by David Aiketgate on topic Re: Change Speedo Heard Cluster from MK1 to MK2
Posted 13 years 6 months ago #24066
Hi and :welcome2:
I remember Kara having that mod done, but I can't find the HOW TO anywhere?:shrug:
I will keep looking, or, hopefully someone else can help you :broon:
Last Edit:13 years 6 months ago by David Aiketgate
Replied by Schoppi on topic Aw: Re: Change Speedo Heard Cluster from MK1 to MK2
Posted 13 years 6 months ago #24069
Hi David,
that sounds optimistically :woohoo:
In the German forum it looks like nobody had done this before.
BR
Schoppi
by Schoppi
Posted 13 years 6 months ago #24070
So far I have found this
You will need a speedo transducer (the part onto the top of the gearbox that converts the gearbox speedo into a digital signal. Then you need to supply power to it by taking a feed from the black and pink wire from the ECU loom to the transducer. Then take an orange a white wire from the transducer to the back of the clocks. I think the 3rd pin in the transducer plug is either earth or not used. Hey presto a working speedo! The rev counters are all the same!
The following user(s) said Thank You: Schoppi
Posted 13 years 6 months ago #24071
Hi David,
you make me sooo happy :woohoo:
BR
Schoppi
by Schoppi
Posted 13 years 5 months ago #24494
I did it! :woohoo:
The new MK2 Speedo is assembled and works proper. The only fail function I have is that the lamp for the ABS system is lighting. The ABS System is working; I tested it on a wet street.
Right now I disassembled the lamp, but this should not be the final solution.
Photos from the assembly you can find attached.
File Attachment:
File Name: Speedo.zip
File Size:500 KB
Is there any idea how to solve the problem? :-?
SPEED TRANSDUCER CONNECTION AT GEARBOX
PLUG AT THE ECU
CABLE ROUTE FROM REAR TO FRONT
Last Edit:13 years 5 months ago by Schoppi
Last edit: 13 years 5 months ago by David Aiketgate.
Replied by David Aiketgate on topic Re: Change Speedo Head Cluster from MK1 to MK2
Posted 13 years 5 months ago #24496
Great news, mate! :thumbsup:
As for the Abs light, if the system is working but the light is coming on it would suggest a simple electrical fault in the warning light circuit.
I will upload your photos so that we can all see them.:broon: Would you like to add some titles to them?
CONTINUATION OF PHOTOS
CABLE ROUTE TO FRONT (cont)
GROUND CONNECTION UNDER DASHBOARD
PLUG BELOW DASHBOARD
IMPULSE WIRE
WORKING MK2 SPEEDO
NEW SPEEDO(close up)
ABS LIGHT FAULT
Last Edit:13 years 5 months ago by David Aiketgate
Replied by Schoppi on topic Re: Change Speedo Head Cluster from MK1 to MK2
Posted 13 years 5 months ago #24508
Hi David,
OK, no problem. :thumbsup:
I gave each picture a title. Also you can find a PDF-documents which describes the differences between the MK1 and MK2 plugs at the fuse box site.
File Attachment:
File Name: Speedo2.zip
File Size:501 KB
File Attachment:
File Name: PlugsMGFMK1MK2.pdf
File Size:217 KB
Any comment, feel free :woohoo:
by Schoppi
Replied by Rich in Vancouver on topic Re: Change Speedo Head Cluster from MK1 to MK2
Posted 13 years 5 months ago #24519
This is a great mod!
Something else to add to my list.
One question; Does the replacement speedo head carry the total mileage (from it's previous car) in it's memory,
and is it possible to input your car's proper mileage into it?
Posted 13 years 5 months ago #24525
The speedo unit retains the mileage, and I don't think it is possible to change it.:shrug:
Replied by rough luck on topic Re: Change Speedo Head Cluster from MK1 to MK2
Posted 13 years 5 months ago #24527
If you had a friend with a fully wired car that takes a mark two set of clocks you could change the mileage with the right connector and software from ebay, I'm just not sure the software would do it on a retro fit
The following user(s) said Thank You: David Aiketgate, bryan young
Posted 13 years 5 months ago #24528
To adjust the speedo to the original kilometers will be one of the next actions. Due to the fact that I will be fair-minded also to myself, I will do it soon. I documented the kilometers of both units so that I can adjust it at any time when I have found the way out, especially for my modified version. ;)
by Schoppi
Time to create page: 0.896 seconds
