SS underfloor pipes failure
SS underfloor pipes failure was created by gotenks1321
Posted 13 years 5 months ago #24570
Anyone else had this? Noticed mine were definitely dripping from the front bracket so just taken them off. Can't bloody see where it is so not sure how I'm going to fix(bodge) it for the time being :lol:
Anyone else had any fail?
Replied by Kameleon on topic Re: SS underfloor pipes failure
Posted 13 years 5 months ago #24573
EEk -first time I have heard that!
I was down at Stirling Automotive and they commented that it's something they've never seen either whilst trying to sell me a set. Is it the rubber hose join that's leaking or the metal pipe itself?
Replied by gotenks1321 on topic Re: SS underfloor pipes failure
Posted 13 years 5 months ago #24575
I hadn't heard of it either. I was under the impression of fit them and never worry again pretty much :yesnod:
From what I can see is it's leaking where the front most bracket is welded to the pipe itself. I've cleaned them up and dried everything and there is still water that I can just about see under it. They did only leak when the car was cooling down but that was enough to go through a 5 litre bottle of coolant in a week :blink:
I've got some chemical metal stuff which I think i'll try for the time being and get another set ordered to replace next week,
Last Edit:13 years 5 months ago by gotenks1321
Last edit: 13 years 5 months ago by gotenks1321.
Replied by petevick on topic Re: SS underfloor pipes failure
Posted 13 years 5 months ago #24578
sounds like an over enthusiastic welder got the metal a little too hot and blew a hole into the pipe. Not sure how good chemical metal is under pressure, but it will make any future welding a pain having to clean it all off.
Pete Vickerstaff
Posted 13 years 5 months ago #24579
I think you might be right there Pete, that particular area on the pipe does look different to the rest. Hard to explain really but I'd imagine it's either from the coolant or from the welding.
The chemical metal will only be a temp fix as I need the car for the beginning of next week, as soon as I can get hold of a new set of pipes I'll swap them over. I suppose the current ones could possibly be welded and fixed, hadn't really thought that far ahead :lol:
Replied by David Aiketgate on topic Re: SS underfloor pipes failure
Posted 13 years 5 months ago #24587
gotenks1321 wrote: I think you might be right there Pete, that particular area on the pipe does look different to the rest. Hard to explain really but I'd imagine it's either from the coolant or from the welding.
Any chance of a warranty claim?
Posted 13 years 5 months ago #24591
Bought them in October '08 from MGOC so I doubt it unfortunately :lol: The fact that the putty has now cured and I'm off out to fit them again might cause some issues with a claim too ;)
Been thinking about the possibility of just replacing them with a length of silicon piping with suitably space brackets to hold it all secure and protect it. Stronger than rubber and more flexible than the steel ones, will have to price it up and see :thumbsup:
Replied by Herbie on topic Aw: Re: SS underfloor pipes failure
Posted 13 years 5 months ago #24599
Do it properly Dan, don't save at the wrong end ;)
MGF 1.8i - Nighfire Red (CAQ) - Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling
by Herbie
Replied by gotenks1321 on topic Re: Aw: Re: SS underfloor pipes failure
Posted 13 years 5 months ago #24611
Herbie wrote: Do it properly Dan, don't save at the wrong end ;)
No need to worry there Stephan :) The fix I've done today is only temporary and if I go for the silicone route it'll be done properly and will last the lifetime of the car :yesnod:
Posted 13 years 5 months ago #24663
Temp fix didn't work :(
Cost wise to replace the underloor pipes with silicone is looking around £100 so I think I may go down that route.
Can anyone think of any reason not to?
  • psymon
  • 2001 MGF 1.8 in MNX
Replied by psymon on topic Re: Aw: Re: SS underfloor pipes failure
Posted 13 years 5 months ago #24664
Probably less heat loss through the silicon than the SS, don't know if that would be a problem though, The little additional cost does make the Silicon an attractive option.
Whats your plan for Brackets?
by psymon
Posted 13 years 5 months ago #24670
Do the steel ones lose that much heat? Hadn't really thought about that.
For brackets I will probably adapt the existing ones from the SS pipes for the time being and make something up that's a bit more long term once I know it's all working ok.
Time to create page: 0.572 seconds
