Gear change problem - Bellcrank?
The cable gaiter is completely perished, so I have ordered a replacement, but that isn't the cause of the problem is it?
I've taken a couple of pics so that I can get some advice
Is this how it should look and, if so, does that mean the problem could be at the gear knob end?
Thanks.
OK, due to my complete ignorence regarding the mysteries of cars I really don't know what I am looking for :oops:
Thanks.
that looks pretty much ok, altho I can't see the state of the vertical cable.
Pete Vickerstaff
MG F/TF Central
- your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Replied by David Aiketgate on topic Re: There's always something! Gear cable this time.
Posted 13 years 5 months ago #26457David
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: There's always something! Gear cable this time.
Posted 13 years 5 months ago #26462First get them to move the gear lever front to back. You should see the lower cable move.
(On my car when this cable broke the gearshift just went limp.)
Next have them move the cable side to side. This should move the upper cable.
(Apparently this cable seldom breaks.)
If they move or seem jammed there may be another problem.
Have you tried lubricating all of the linkage bits?
Replied by Laz1957 on topic Re: There's always something! Gear cable this time.
Posted 13 years 5 months ago #26486However it won't move side to side at all which means a problem with the upper cable (is that correct?)
Or maybe the problem is at the gear shift end - I guess I better check that end too
- Rich in Vancouver
Posted 13 years 5 months ago #26487Once the car is up in the air things may be a bit more obvious. Before stripping out the console I would be inclined to pop the cables off the linkage at the rear and see if the gearlever and cables move with them disconnected. If you were to hold the cable ends and get an assistant in the car to move the gearlever you will be able to tell if the cables and the gearlever assembly are free. It could be that the bellcrank has siezed. If everything is free that would point to a problem with the gearbox, which of course is the last thing you want. :sick:
Rich
Replied by petevick on topic Re: There's always something! Gear cable this time.
Posted 13 years 5 months ago #26488Pete Vickerstaff
MG F/TF Central
Posted 13 years 5 months ago #26489Please Log in or Create an account to join the conversation.
Posted 13 years 5 months ago #26490David
Posted 13 years 5 months ago #26491Please Log in or Create an account to join the conversation.
Posted 13 years 5 months ago #26492The parts in the lower section are the bell crank assembly.
15 is the bell crank itself
16 is the roll pin
- bryan young
Replied by bryan young on topic Re: There's always something! Gear cable this time.
Posted 13 years 5 months ago #26518David Aiketgate wrote:
But what's this? It looks like a broken piece of metal.
Is that a picture of yours :shrug: or laz1957?? ~~ is that at the gearbox end or front end
Saved the picture on my T Bar file, thank you. :thumbsup:
