Gear change problem - Bellcrank?
Replied by petevick on topic Re: There's always something! Gear cable this time.
Posted 13 years 4 months ago #26519
both those pics are at the gearbox end
Pete Vickerstaff
Replied by David Aiketgate on topic Re: There's always something! Gear cable this time.
Posted 13 years 4 months ago #26522
Bryan,
those are Larry's(Laz1957) photos, with my notes attached, This is the backend of the car under the engine area, as Pete says.
The bellcrank is at the other end of the gear cables from the gear lever.
Last Edit:13 years 4 months ago by David Aiketgate
Replied by bryan young on topic Re: There's always something! Gear cable this time.
Posted 13 years 4 months ago #26526
David Aiketgate wrote: Bryan,
Thank you, all is clear now. that looks like new cables are needed and would seem sensible to fir the uprated bell crank from Mike Satur, dont want to be doing this job again in too much of a hurry. I understand that the new cables from Portland Trading have an adjustment to "tighten" up slack?? they are £130 a pair or £70 each plus carriage, from them direct. :thumbsup:
Replied by Laz1957 on topic Re: There's always something! Gear cable this time.
Posted 13 years 4 months ago #26532
Would someone be kind enough to post a picture of how this should look, so I can see what's wrong with mine please?
Looks like new cables required then?
by Laz1957
Replied by Rich in Vancouver on topic Re: There's always something! Gear cable this time.
Posted 13 years 4 months ago #26533
Here's a link to Portland Trading's page on the MGF cables. They have good pics of how the cable ends should look.
By the time mine failed they looked nothing like these! There is also a bellcrank incorporated in the shifter mechanism itself. It has a nylon bushing that could cause major problems if it fails but I don't know if they ever do. It sure looks like a part that would benefit from an occasional application of grease. Speaking of the gearchange, do the cables at the front end just snap on and off of the balls? EDIT: Yes they do.
Portland MGF Cables
Last Edit:13 years 3 months ago by Rich in Vancouver
Last edit: 13 years 3 months ago by Rich in Vancouver.
Replied by David Aiketgate on topic Re: Gear change problem - Bellcrank?
Posted 13 years 3 months ago #27112
OK separated this out from the gear cable how to, to simplify the how to.
Last Edit:13 years 3 months ago by David Aiketgate
Last edit: 13 years 3 months ago by David Aiketgate.
Time to create page: 0.583 seconds
