Resolved! Jerky at slow speed
Replied by [email protected] on topic Resolved! Jerky at slow speed
Posted 1 year 11 months ago #200765
Can you see it in my attachments?
Last Edit:1 year 11 months ago by [email protected]
Last edit: 1 year 11 months ago by Raccoon. Reason: pic inserted
Replied by Raccoon on topic Resolved! Jerky at slow speed
Posted 1 year 11 months ago #200766
now we can :-)
by Raccoon
Posted 1 year 11 months ago #200771
I can't find this thing
Replied by Airportable on topic Resolved! Jerky at slow speed
Posted 1 year 11 months ago #200772
I fear you may be looking at the wrong side of the engine. Your pictures are of the right hand side of the rear of the engine, you need to look at the left hand side of the front.
Sort of above the clutch slave cylinder.
Posted 1 year 11 months ago #200774
Photo please
Replied by David Aiketgate on topic Resolved! Jerky at slow speed
Posted 1 year 11 months ago #200776
Nope!
It's on the exhaust manifold side of the engine. Looking from the back of the car, the sensor is far left of the engine on the coolant outlet.
Arrow points to sensor
Last Edit:1 year 11 months ago by David Aiketgate
Last edit: 1 year 11 months ago by David Aiketgate.
The following user(s) said Thank You: j0ris
Posted 1 year 11 months ago #200777
Never one to turn down a photo opportunity however on this occasion I’ll decline. Not wishing to remove the hard top, unclip the rear of the hood & raise it, remove carpet & sound deadening, unbolt the cover plate in order to take a picture of the sensor’s whereabouts.
David’s picture & my description should have alerted you to its general geographic position & as I now see his second picture has reenforced its whereabouts.
Posted 1 year 10 months ago #200849
Can only see a black one, is that it?
Last Edit:1 year 10 months ago by [email protected]
Last edit: 1 year 10 months ago by David Aiketgate. Reason: Inserted pics
Posted 1 year 10 months ago #200850
Yes, that is the engine coolant temp. sensor for the ecu.
If you are replacing it ensure you get the correct one, (MEK000030 followed by a letter depending on whether you get oem or aftermarket) NOT the sensor for the coolant temp gauge.(YCB100370 or YCB100420))
The brown sensor mentioned was used on mk1 Fs, later vehicles used a black sensor.
Last Edit:1 year 10 months ago by David Aiketgate
The following user(s) said Thank You: sworkscooper, Airportable, j0ris
Posted 1 year 10 months ago #200851
I was going to get this one
https://autobarn.com.au/ab/Autobarn-Category/Shop-our-Full-Ranges-by-Brand-%7C-Autobarn/Tridon/Coolant-Temperature-ECU-Sensor/p/SP115102
which is the same as this Ebay one
Tridon Coolant Temperature Sensor for MG MGF TF 1.8L VVC 18K4K DOHC 16V
Buy It Now
Last edit: 1 year 10 months ago by [email protected].
Posted 1 year 10 months ago #200853
Might I make an observation. We have got to start somewhere on the knowledge ladder with our cars, however it is not the function of the T-Bar to diagnose your problems or advise which part to buy. You have the information on your car & David has furnished you with all the information to make an informed purchase; to ascertain which sensor you need, remove the connector & observe the cap colour & you'll be well on the way to deciding which to buy.
It is also polite to thank each contributor for the help received.
Posted 1 year 10 months ago #200855
My my you are a happy sort, I didn’t give you incorrect information & my comments are as valid as any other contributor. If the general consensus of members on here is for me to butt out I will gladly, however until that happens I will feel free to comment as I feel fit.
Writing in upper case, with aggression & with very little provocation might give other members an indication of your personality & they, like me, might be disinclined to give you any assistants & a wide berth.
I wish you well with your problem & hope you resolve it to your satisfaction, I will however be striding over any post with your name attached.
Time to create page: 1.424 seconds
