Ball Joint Socket
I borrowed one last time I did the front upper ball joint, but I have been meaning to get my own since I did the rears.
It is a 1/2" drive 1 - 13/16" socket and is a perfect fit, in depth as well as size, for the ball joints on the F/TF.
It costs £14.99, but I think it is a valuable addition to your tool kit for removing ball joints, along with a 12V impact driver.
Spookily enough (and I didn't notice this until I got home) the label actually says Ball Joint Socket.
- Rich in Vancouver
I have a 1 15/16" socket that I bought specifically to use on the crank pulley of MG B-Series engines.
(Of which I no longer own any)
Is it the same size-Of Course Not!
Is that why you spend so long polishing yours?David Aiketgate wrote: Oi loikes nice shiny tools, oi do. :yesnod:
- a Guest
- Visitor
Enjoy self any way.
Phaaa, shiny :pinch: and we have no halfords in DEDavid Aiketgate wrote: Oi loikes nice shiny tools, oi do. :yesnod:
That's shiny
Draper tool HTD-AF 1 13/16 sourced from fleebay some years ago.
The bag on the right was the packing .... Had a big laughter when I pulled it out of my letter box.
Daz,
no worries with that cheap 12V impact drivers. I own one myself.
They are quite secure and don't hurt due to their design. They only do a very few short but heavy kicks. Easy to hold with one hand only.
The impact wrench that I have just spins up to speed and gives a short thwack. Doesn't feel as though it is ever in danger of damaging anything really and was a quick and easy solution to the problem. Pete has the same wrench and uses his successfully too.
That's shiny .
Shiny chrome is just sooo last year.
- a Guest
- Visitor
To be fair.cjj wrote: Get yourself a 12V wrench. It was loose in 10 seconds.
They are for sure not designed for professional long term heavy use
Also to slow for a quick access on a load of screws, and not any torque restriction while tightening bolts.
So after "on" comes ... "off"
Had to DIY repair my 12V thingy already after the first 8 wheel bolts. It stopped working cause a faston 6.3 connector had come loose inside at the power switch. Cheap and thin brass connectors
However it works for this ball joints and aswell for the heavy load crank nut.
Didn't try with the wheel hub screw, though.
