MGF Brake disc removal?
Do I need to fit the disc retaining screws when I fit the new discs as there is only 1 on the other side anyway?
Get the hub faces nice and clean with no rust etc or the new disks won't sit flat.
I fitted stainless steel retaining screws.
So you recon I can just drill out the old screws & not replace them??
The hub faces are almost as new, no rust at all. I was just going to give them a light smear of Copper grease when I put em back together.
Yes, as was already said, the wheel holds them on anyway.Slippy;2846 wrote: So you recon I can just drill out the old screws & not replace them?
- a Guest
- Visitor
David Aiketgate;2868 wrote: Yes, as was already said, the wheel holds them on anyway.
But you can't check for run out without the retaniing screws.
Mike
http://cgi.ebay.co.uk/MGF-MGTF-MG-TF-STAINLESS-DISC-BRAKE-STEADY-SCREWS_W0QQitemZ380108408413QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item58803a065d
CJJ;2876 wrote: There are some stainless steel ones on e-bay for a couple of quid
Yeah, Ive seen them thanks Clive but I dunno if I can get the bits of old screw out yet. If I can, I will get some. Cant have enough stainless (even tho they wont be seen)
Yves Adele Harlow;2953 wrote: I'm in the same boat as you hun! Took the discs of yesterday and notice the retaining screws were either not there, so chewed up, or rounded off! :frown: Impact driver is the way forward me thinks! Plus they're fun to play with! :lol:
Ive been advised to get some Loctite Freeze & Release, its like a WD40 type releasing spray but freezes the nut / bolt down to -45 degrees, causing the seal formed by the rust to crack & allowing the lubricant to get in.
Never heard of it before but Im going to have a look for some over the weekend if I get chance & give it a go. Im gonna get an impact driver too, just so I can bash away at it in the garage :naughty::smokin:
Just out of curiosity what colour do you lot think I should do my calipers (the standard type) Im going to paint them but dont want them too OTT. My first thouhght was all Black, then I decided on all silver, then I thought of the big square bit black with the other part silver but now I have just ordered some bright orange, now the thought is to do the big square bit black with the other bit Orange??? :dunno:
The drilled / grooved discs I think im going to get have a black anti rust coating on them, a bit like the black diamond ones.
Slippy;2967 wrote: Ive been advised to get some Loctite Freeze & Release, its like a WD40 type releasing spray but freezes the nut / bolt down to -45 degrees, causing the seal formed by the rust to crack & allowing the lubricant to get in.
That Loctite stuff sounds such good fun! I wonder what else you can spray with it... :CJJ:
I must admit if it were me I'd do the big square bit orange and the other bit black. I think if the majority of the colour is black or silver it just gets lost and orange calipers would be so unique & eye catching! :thumbsup:
You do have a stunning F btw - keep meaning to tell you it's one of my favourite colours! If I were you I'd totally spray my vents & console orange - it's such a beautiful, strong vibrant colour that you've got to own it! :piratebang:
It is worth persevering to get new screws in. Not necessary, but they prvent the disc from moving when you take the wheels off.
I have some of the freeze spray and it has never worked for me. :dunno:
