MGF Brake disc removal?
MGF Brake disc removal? was created by slippy
Posted 15 years 2 weeks ago #2823
Im just about to order my new drilled / grooved discs & Greenstuff pads but thought Id start by removing the old ones at the front. Calipers off no probs but the little disc retaining screws, although looking quite newish & shiney seem to be made out of chewing gum or something, as soon as I touched them with the screwdriver they were chewed to bits. I have drilled them out but not got all the old screw out yet. Is this what i can expect from all 4 corners or is there a secret to getting them off??
Do I need to fit the disc retaining screws when I fit the new discs as there is only 1 on the other side anyway?
by slippy
Replied by andycolm on topic MGF Brake disc removal?
Posted 15 years 2 weeks ago #2831
Mine were fairly new so came out ok, but I didn't refit them. The disks are held on by the wheelstuds and wheels so they are going nowhere. You may find a big hammer to beat the old disks off are needed, they seize onto the hubs.
Get the hub faces nice and clean with no rust etc or the new disks won't sit flat.
Replied by cjj on topic MGF Brake disc removal?
Posted 15 years 2 weeks ago #2835
An impact driver usually helps.
I fitted stainless steel retaining screws.
Replied by slippy on topic MGF Brake disc removal?
Posted 15 years 2 weeks ago #2846
Shifting the disc was not the problem, a few light taps with a hammer & off it came, it was how soft the metal was on the disc retaining screw that got me.
So you recon I can just drill out the old screws & not replace them??
The hub faces are almost as new, no rust at all. I was just going to give them a light smear of Copper grease when I put em back together.
by slippy
Replied by David Aiketgate on topic MGF Brake disc removal?
Posted 15 years 2 weeks ago #2868
Slippy;2846 wrote: So you recon I can just drill out the old screws & not replace them?
Yes, as was already said, the wheel holds them on anyway.
  • Visitor
  • Visitor
Replied by a Guest on topic MGF Brake disc removal?
Posted 15 years 2 weeks ago #2869
David Aiketgate;2868 wrote: Yes, as was already said, the wheel holds them on anyway.
But you can't check for run out without the retaniing screws.
Mike
Posted 15 years 1 week ago #2936
CJJ;2876 wrote: There are some stainless steel ones on e-bay for a couple of quid
http://cgi.ebay.co.uk/MGF-MGTF-MG-TF-STAINLESS-DISC-BRAKE-STEADY-SCREWS_W0QQitemZ380108408413QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item58803a065d
Yeah, Ive seen them thanks Clive but I dunno if I can get the bits of old screw out yet. If I can, I will get some. Cant have enough stainless (even tho they wont be seen)
by slippy
Replied by kara on topic MGF Brake disc removal?
Posted 15 years 1 week ago #2953
I'm in the same boat as you hun! Took the discs of yesterday and notice the retaining screws were either not there, so chewed up, or rounded off! :frown: Impact driver is the way forward me thinks! Plus they're fun to play with! :lol:
by kara
Posted 15 years 1 week ago #2967
Yves Adele Harlow;2953 wrote: I'm in the same boat as you hun! Took the discs of yesterday and notice the retaining screws were either not there, so chewed up, or rounded off! :frown: Impact driver is the way forward me thinks! Plus they're fun to play with! :lol:
Ive been advised to get some Loctite Freeze & Release, its like a WD40 type releasing spray but freezes the nut / bolt down to -45 degrees, causing the seal formed by the rust to crack & allowing the lubricant to get in.
Never heard of it before but Im going to have a look for some over the weekend if I get chance & give it a go. Im gonna get an impact driver too, just so I can bash away at it in the garage :naughty::smokin:
Just out of curiosity what colour do you lot think I should do my calipers (the standard type) Im going to paint them but dont want them too OTT. My first thouhght was all Black, then I decided on all silver, then I thought of the big square bit black with the other part silver but now I have just ordered some bright orange, now the thought is to do the big square bit black with the other bit Orange??? :dunno:
The drilled / grooved discs I think im going to get have a black anti rust coating on them, a bit like the black diamond ones.
by slippy
Posted 15 years 1 week ago #2974
Slippy;2967 wrote: Ive been advised to get some Loctite Freeze & Release, its like a WD40 type releasing spray but freezes the nut / bolt down to -45 degrees, causing the seal formed by the rust to crack & allowing the lubricant to get in.
That Loctite stuff sounds such good fun! I wonder what else you can spray with it... :CJJ:
I must admit if it were me I'd do the big square bit orange and the other bit black. I think if the majority of the colour is black or silver it just gets lost and orange calipers would be so unique & eye catching! :thumbsup:
You do have a stunning F btw - keep meaning to tell you it's one of my favourite colours! If I were you I'd totally spray my vents & console orange - it's such a beautiful, strong vibrant colour that you've got to own it! :piratebang:
by kara
Posted 15 years 1 week ago #3000
Do them bright orange.
It is worth persevering to get new screws in. Not necessary, but they prvent the disc from moving when you take the wheels off.
I have some of the freeze spray and it has never worked for me. :dunno:
Time to create page: 0.523 seconds
