Help.
Help. was created by Leigh Ping
Posted 13 years 3 weeks ago #30422
I tried using the shoutbox to no avail. Spark plugs is the query :). Do the plug caps just pull off? Or do they need to be twisted a certain way first? Thanks.
  • psymon
  • 2001 MGF 1.8 in MNX
Replied by psymon on topic Re: Help.
Posted 13 years 3 weeks ago #30426
From Broons site, might help
http://www.iain-brown.com/sparkplugs.html
by psymon
Replied by petevick on topic Re: Help.
Posted 13 years 3 weeks ago #30427
they just pull off, but can become 'stuck' by the suction effect of the rubber end of the HT lead
Pete Vickerstaff
Replied by Leigh Ping on topic Re: Help.
Posted 13 years 3 weeks ago #30429
Thanks both. They seem to be stuck. Any ideas on a fix? :)
Posted 13 years 3 weeks ago #30430
Leigh Ping wrote: Thanks both. They seem to be stuck. Any ideas on a fix? :)
pull even harder :broon:
....and twist then slightly to break the sticktion.
Pete Vickerstaff
Last Edit:13 years 3 weeks ago by petevick
Last edit: 13 years 3 weeks ago by petevick.
Posted 13 years 3 weeks ago #30431
Thanks Pete. I'm already using tremendous force with no joy. I'm going to try some wd40 now.
Replied by David Aiketgate on topic Re: Help.
Posted 13 years 3 weeks ago #30432
I ended up using so much force that I pulled one of the leads out of the rubber cap, it was so well stuck. As I was replacing the leads anyway, that wasn't a problem. The problem was that the stupid cap was still stuck to the spark plug.
Posted 13 years 3 weeks ago #30433
just to clarify, is it the HT leads that you can't pull off the spark plugs, or is it the spark plugs you can't remove from the head ?.
Pete Vickerstaff
Posted 13 years 3 weeks ago #30435
It would have broke. So, I didn't go any further to prevent complications. I put it all back together.. for now :). Cheers for the help all.
Posted 13 years 3 weeks ago #30436
Buy a new set of leads, you know you want to! :yesnod:
Posted 13 years 3 weeks ago #30438
David Aiketgate wrote: Buy a new set of leads, you know you want to! :yesnod:
It all looks relatively new under there and I know the previous chap looked after it with no expense spared. The last service was in June. So, no drama at this time. I was changing them as a fellow LPG'er said they benefit from iridium plugs and when sitting in traffic the revs sometimes fluctuate from 500 to 1000 (lpg most likely, as when I switch to petrol it stops immediately).
Last Edit:13 years 3 weeks ago by Leigh Ping
Last edit: 13 years 3 weeks ago by Leigh Ping.
Time to create page: 1.866 seconds
