Help.
- Leigh Ping
http://www.iain-brown.com/sparkplugs.html
Pete Vickerstaff
MG F/TF Central
- your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
- Leigh Ping
pull even harder :broon:Leigh Ping wrote: Thanks both. They seem to be stuck. Any ideas on a fix?
....and twist then slightly to break the sticktion.
Pete Vickerstaff
MG F/TF Central
- Leigh Ping
Pete Vickerstaff
MG F/TF Central
- Leigh Ping
- Leigh Ping
It all looks relatively new under there and I know the previous chap looked after it with no expense spared. The last service was in June. So, no drama at this time. I was changing them as a fellow LPG'er said they benefit from iridium plugs and when sitting in traffic the revs sometimes fluctuate from 500 to 1000 (lpg most likely, as when I switch to petrol it stops immediately).David Aiketgate wrote: Buy a new set of leads, you know you want to! :yesnod:
