MG TF locking features
I need some help, please, determining the locking features of a just purchased 2003 MG TF 115.
The garage I purchased it from is adamant that it is functioning as intended, and I am disputing this
on the grounds that no manufacturer would release a model that functioned in the way that this does.
I have a key and a two button remote. The key locks/unlocks both doors individually but there is no central locking.
The remote locks/unlocks the driver’s door only. The remote activates/deactivates the alarm/immobiliser.
I would appreciate knowing if the car was manufactured with central locking and, if so, did it operate on either door, or driver’s door only.
Was the car supplied with remote control or was this fitted afterwards.
Either way it is my opinion that the remote should still operate on both doors. Any agreement, or otherwise, would be welcome.
Your comments will be much appreciated.
paul16442 wrote: Hi
I don't think the 115 came with central locking as standard. It was the entry level car and I could be wrong but I'm sure it didn't have speakers in the T bar as standard either.
" The 115 model looks the same as all the others but a few basic toys are worth asking for when you buy. I had central locking put on for free which does not come in the basic package. Also the 115 does not have the speakers behind the seats and no interior alarm system. All these come as standard in the 1.8 models."
If yours has the alarm and is a genuine rover item, I suspect it may have been added as an option, however I would have expected central locking to also have also been added at the same time.
Unless someone has bodged the job.
- bryan young
paul16442 wrote: Hi
If you can give me the VIN number i can try to check what was a standard car, i know they left some options off the 115 variant but didnt think that central locking was one of them. Did you say that you have a lock barrell on each door?? if you dont want to post your Vin on here, email me at [email protected] or PM me here. :yesnod:
- bryan young
paul16442 wrote: Hi
The TF115 was not fitted with central locking until model year 2004 :nonod: found this on another site :-
Up to and including model year 2004, the TF 115 came without remote central locking as standard. All the cabling and connectors are in place for central locking but the door latches do not contain the necessary motors and gears and the ecu does not have the central locking functions programmed. To fit central locking involves changing the door latches and, if necessary, re-programming the ecu.
Some points to note.
The 2004 model year production would have commenced mid 2003.
Does your car have a lock barrell on the passenger door ? if it has then the central locking has been retro fitted and may not have been set up correctly! ~ the main ECU has to be told that C/L has been fitted using the MGR testbook T4 programme.
You should have two keys and two remote fobs, please confirm this & have you got the EKA code Emergency Key Access Code (four digit number)
If you lock the car with the fob, then wait a minute and open the drivers door with the key, put the key in the ignition and start the car. if it starts the immobiliser is not working! if nothing happens, lock and unlock the car with the fob and start again. you can check the alarm function the same way. put hood down, lock with fob, wait 60 seconds, put your hand in the car and the alarm will go off.
Be very interested in your replies.
And a big welcome to the T Bar :woohoo:
Email returned from address given
Thanks for taking the trouble to reply. The car has a barrel lock on the passenger side.
I have two keys and two remote fobs, but no EKA. The immobiliser functions as you describe. The
alarm does not appear to respond to movement but is activated when the door is opened.
The VIN is SARRDMBEB3D614212
Thanks
To tell if the passenger actually has the central locking motor, it would be necessary to take the door card off and check the wiring to the lock. If I recall correctly the 115 standard lock looks the same externally, but doesn't have a motor in the casing.
- bryan young
David Aiketgate wrote: As I thought the motion sensor is not fitted to the 115. :nonod:
That is correct, they even have the same part number!!! :omg:
