Two questions - one MG related
Two questions - one MG related was created by David Aiketgate
Posted 12 years 11 months ago #33270
1/. Would anybody who has an MGTF newer than 02 let me know if the fuel gauge stays at the level or settles back to zero when the ignition is off/overnight?
2/. could somebody tell me what i should be connecting and where to in the following ( figure 2)?
It's a thermostat for the heating - lcd with battery backup.
I (think I) know I need a live, a switched live, and a neutral but so far I've gone through three fuses and several loud bangs. :coat:
Last Edit:12 years 11 months ago by David Aiketgate
Last edit: 12 years 11 months ago by David Aiketgate.
Replied by andy1970h on topic Re: Two questions - one MG related
Posted 12 years 11 months ago #33271
Can't help with number 2 but on my 04 TF the fuel gauge drops to zero with the ignition off.
  • psymon
  • 2001 MGF 1.8 in MNX
Replied by psymon on topic Re: Two questions - one MG related
Posted 12 years 11 months ago #33272
don't think you need a ground as its battery powered. Diagram doesn't show anywhere for ground.
Perement live to pin3 , pin2 probably no connection and pin1 return back to boiler or timer.
by psymon
Replied by David Aiketgate on topic Re: Two questions - one MG related
Posted 12 years 11 months ago #33273
andy1970h wrote: Can't help with number 2 but on my 04 TF the fuel gauge drops to zero with the ignition off.
That's a relief, because I had to replace the fuel gauge on mine and prior to swapping the fuel gauge stayed up but now it drops. i thought I might have broken it. ;)
Posted 12 years 11 months ago #33274
Psymon wrote: don't think you need a ground as its battery powered. Diagram doesn't show anywhere for ground.
It's only battery back up. It's supposed to run off the mains.
I can get it to switch the pump on and off with the thermostat and display from the battery. Take the batteries out and it stops working.:shrug:
Replied by PQD44 on topic Re: Two questions - one MG related
Posted 12 years 11 months ago #33275
David for 2, Live in goes to 3 COM, when the temperature drops the thermostat will switch and allow the 'switched live' to go out from 1. You will not normally use 2 unless you want a switched live when the temperature is above the one you set, if for instance you want to switch a cooling appliance on.
The connection of Neutral is made at the appliance/boiler.
Phone me if you need any more help
Posted 12 years 11 months ago #33277
Psymon was correct sorry I was slow typing.
Your data sheet says the thermostat is battery powered NOT mains
Posted 12 years 11 months ago #33278
Ah, That probably explains why when I tried to connect all three there was a big bang. I had live to 3 switch to 2 and neutral to 1.
Posted 12 years 11 months ago #33280
:omg: Oooouuuch :blink: No wonder you got a bang, still it wakes you up :bust:
Replied by Tipper on topic Re: Two questions - one MG related
Posted 12 years 11 months ago #33288
It's not mains powered...it's battery powered!
As PDQ says, live to 3 and 1 goes to the switched item ie the pump/boiler/heat source.
by Tipper
Posted 12 years 11 months ago #33295
Ok, it's battery powered. :yesnod:
Now if i put an ohmeter across 3 and 2 and rotate the dial I get an on /off when the thermostat clicks.
If I put the ohmeter across 3 and 1 and rotate, I get nothing.
Replied by cjj on topic Re: Two questions - one MG related
Posted 12 years 11 months ago #33298
Have a look at page 15 on here: http://www.thermsaver.co.uk/media/pdf/controls/thermsave-celect-programmable-thermostat-guide.pdf
NO means Normally Open and is Number 1 on your diagram.
NC means Normally Closed and is number 2 in your diagram. Nothing is connected to this one.
Last Edit:12 years 11 months ago by cjj
Last edit: 12 years 11 months ago by cjj.
Time to create page: 0.557 seconds
