Two questions - one MG related
- bryan young
Replied by bryan young on topic Re: Two questions - one MG related
Posted 12 years 11 months ago #33302PQD44 wrote: David for 2, Live in goes to 3 COM, when the temperature drops the thermostat will switch and allow the 'switched live' to go out from 1. You will not normally use 2 unless you want a switched live when the temperature is above the one you set, if for instance you want to switch a cooling appliance on.
The connection of Neutral is made at the appliance/boiler.
Phone me if you need any more help
Correct, live from boiler to 3 (com) Live back to boiler from 1, to energise boiler, No neutral and no Earth. Presume batteries are to activate switch? - Only ever used Honeywell which need a neutral to activate the switch.
David Aiketgate wrote: ...Now if i put an ohmeter across 3 and 2 and rotate the dial I get an on /off when the thermostat clicks.
If I put the ohmeter across 3 and 1 and rotate, I get nothing.
You've blown the contacts :nonod: by the sound of it. Time to take it back, tell them you checked it and it doesn't work, whilst trying not to look guilty :oops: or own up and buy a new one like a responsible numpty who has learnt that you ask before connecting the wires. :silly:
At least you're here to tell the tale :thumbsup:
Replied by David Aiketgate on topic Re: Two questions - one MG related
Posted 12 years 11 months ago #33314cjj wrote: Have a look at page 15 on here: http://www.thermsaver.co.uk/media/pdf/controls/thermsave-celect-programmable-thermostat-guide.pdf
NO means Normally Open and is Number 1 on your diagram.
NC means Normally Closed and is number 2 in your diagram. Nothing is connected to this one.
Ta!
So.......................if I want the unit to switch on a pump if a temp reaches a minimum level... 3 and 2...? err 3 and 1? err...
