And another one.. Beryl is losing water
Checked the expansion tank, less than half the amount that was in there... Panic.... Filled back up with water and took a ginger drive home.
Have been out and tried to get the slam panel off (thanks David for the how to, but mine appears to have more awkward nuts than yours!!), gave up.. Started her up, left running for 10 mins to get up to temp, checked, no leaks, no coolent drop.. Nothing..
So come on guru's what is the problem here? I am a little worried about driving her at the moment :dunno:
Angel to Devil in 0.2 seconds...[SIGPIC][/SIGPIC]
David Aiketgate;17095 wrote: Oi, stop using foul language or I'll give you one!
The way we narrowed it down was to take front bumper off, park her on a slope and watch as she started dripping coolant then followed it back to the source (which was the rad & not the hoses! :frown: )
Good luck mate!
I hope its as simple as a rad hose...
- a Guest
- Visitor
Replied by a Guest on topic And another one.. Beryl is losing water
Posted 15 years 3 days ago #3373Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic And another one.. Beryl is losing water
Posted 15 years 3 days ago #3381They are a notorious weak point!:yesnod:
David Aiketgate;3381 wrote: One other point to check is the bleed screw/bolt on the right side of the radiator as you stand staring forlornly under the bonnet.
I did shove my little fingers in there to see if it was wet, but nope, dry as a bone...
Whilst I have you here David, how the hell did you get those annoying bolts undone? I tried to pull the plastic forward to get the spanner on, but couldnt do it? I have 3, even though there should 4 (the two (one of mine has vanished!!) you showed, in your photo's and one either end of the panel)...
Posted 15 years 3 days ago #3386Teri;3383 wrote: I did shove my little fingers in there to see if it was wet, but nope, dry as a bone...
If you've undone all the screws across the top of the bumper, you should be able to pull the plastic forward allowing you to get a spanner onto the two central bolts. I don't know what these other two bolts are, where exactly are they?
Right see that there piccie, where the two nuts are in the middle, well if you go to the left of it, between screw numbers 1 and 2 and the other end 4 and 5, I have 2 more of those blasted nuts and bolts in them holes.. (you can see the holes sort of, in your pic, with no nuts and bolts in)...
Hope that makes sense..
- adamelphick
Replied by adamelphick on topic And another one.. Beryl is losing water
Posted 15 years 3 days ago #3389Please Log in or Create an account to join the conversation.
Posted 15 years 3 days ago #3391Teri;3388 wrote: Sorry I cant do the sticky in bits of writting, so will try and explain..
The two central nut/bolts hold a central bracket. Afaik, there is nothing behind those two positions you have highlighted:dunno: So if you can get the two central nuts off, the slam panel should come out.
If you can't get a spanner in behind them, then there is a big bolt behind each front indicator, holding the bumper on. if you loosen them there should be enough slack to get the spanner in! Be carefull, because there are still hidden bolts attaching the bumper to each wing!
AdamElphick;3389 wrote: I would definitely pop the bumper off and have a look - the rad is easy to change and will save you a fortune if you DIY it!
Ditto we did ours with help from Paul and just an extra little tip for people reading this... once you've detached the hoses from the rad you've got to keep them closed off... a good way to do this if you don't have the right tools is get two spanners... push them tightly against the hose so it closes the hole off... then tie 2 cable ties tightly through the spanner holes. Hope that makes sense!
