Centre Console Question
Replied by MGF MARK on topic Re: Centre Console Question
Posted 12 years 10 months ago #34585
talkingcars wrote:
MGF MARK wrote:
talkingcars wrote: Most head units have a remote on trigger wire, you could wire this to a relay to switch the LED's on and off.
yes they do but dont drive leds on that wire as max current is avout 10ma if you connect the leds it will blow he head unit up
this is used as a logic high (+12V) to switch accesories on so the input to each accesory is high impedence, so little current flow
so if you wanted to use the controll wire then a circuit would need to be built contaning an opamp to buffer the current (the opamp set as a voltage folower but wil only drive 10-20ma so a fet will need to be added to the circuit so acts as a switch simples lol.......
so a solid state relay.............
SOLID STATE RELAY
depends on the current draw on the coil most are 30+mA
mad about cars and bikes :)
Replied by rog1963 on topic Re: Centre Console Question
Posted 12 years 10 months ago #34605
Think I'll go through the oil guage as first suggested ... seems like the easiest solution.
Thanks for all the words. Some of which I'll pretend to understand .... :-? :lol:
by rog1963
Time to create page: 0.634 seconds
