header tank is this bad?
I've filled up 5 litres of water and keeping it in the boot Tuesdays test will be a 40 mile trip the sniff test came back OK though so don't get it
- John and Sue
Commiserations.
- John and Sue
years back on a golf gti: turned out to be a leak on the oil cooler allowing oil into coolant. Dunno if the tf has any history of this problem? The coolant tank looked like yours......
I need this problem like the plague at the minute I've got loads on
Never mind I put it down to previous owners neglect
I'm going to send this link to a few of the mobile mechanics and see what prices I get if you can pass this onto any of your reccomended lot I'd reccomend it :hugs:
Head Gasket
MLS uprated triple layer gasket with shim
Cambelt
Waterpump
Inlet Manifold Gasket
Exhaust Manifold Gasket
Oil
Oil Filter
Coolant flush and refill with fresh O.A.T Antifreeze
Cam Oil Seals if needed
Head Bolts if needed
Lower Oil Rail - I might as well go the full hog if its getting done ? Opinions?
Next...
Stainless Coolant Pipes
Thats it for now. :broon:
Small niggles that I will probably sort myself are:
Need a lambda for [P0141] "02 Sensor Heater Circuit (Bank 1 Sensor 2) - I can sort this myself I think.
Xpower exhaust Install
:help:
Lets hope so.
get the Payern one... its the only one that has the correct sized dowels... all the other kits have smaller dowels which a prone to failure/movement, and a moving head gasket is a very bad thing.
Oz.
Ozzy wrote: if it were me, i would not be getting the MLS gasket, the OE part is better than any of the 3rd party ones...
Oz.
Thats a good point... Anyone else had an experience with this kind of stuff.
http://www.ptp-ltd.co.uk/shop/8_109/mg_rover/mg_f__mg_tf/engine_components/head_gasket_set_-_inc._shimmied_head_gasket.htm
I've PMd you about your expansion bottle too. I need a spare for deff now. :woohoo:
