header tank is this bad?
Oil cap / dip stick fine
Replied by David Aiketgate on topic Re: header tank is this bad?
Posted 12 years 4 months ago #60272David
Whats the history of the car? Have you been using it and its been fine or just got it? If the latter it could be oil from a previous episode still in the system.
Posted 12 years 4 months ago #60279It's possible that a good run will flush it all out, fingers crossed.
seconded, pay even closer than usual attention to oil and water temp gauges. i would remove this froth and if you get no more it was historic. You can get a water vacumn check and an oil sniff for exhaust gases.David Aiketgate wrote: Clean it all off, go on the run. Check everytime you stop! (LET IT COOL DOWN BEFORE REMOVING CAP)Take your AA card. Take extra coolant.
- John and Sue
If you do the run and all is well on your return I'll be really happy to be wrong!!
Good luck!
- Leigh Ping
Leigh Ping wrote: Good luck Ben.
Ta
