Windscreen wiper spring clip fix.
- Leigh Ping
If you have to fit one of these in the rain, at night, miles from home then these pics and video will probably be a help as it can be a bit tricky. Unless you know how.
Here's the 'get you home' fix that I had to fit when we went on the lakes run. Cheap and nasty. But it works... for a while at least.
The spring clip.
Start up the wipers with the ignition lights on. Then stop them by turning the ignition off. So that they end up pointing upwards like this.
In this position, more access is gained to fit the clip.
Slide the clip on. It will be 'tight' at first.
Push it on securely. However, it will probably spring out slightly when in use.
I found this position to be the most secure after testing.
Here's a video of the clip in use. I tested it out for strength and stability.
'The job's a good un.' :broon:
- Yellow Peril
Replied by Yellow Peril on topic Re: Windscreen wiper spring clip fix.
Posted 12 years 5 months ago #60310I know you can't see from above,
got a clip, hope I never need it,
- Leigh Ping
Replied by Leigh Ping on topic Re: Windscreen wiper spring clip fix.
Posted 12 years 5 months ago #60311Fingers crossed.
- Yellow Peril
Posted 12 years 5 months ago #60313should you want to go 'proper job' I have dealt with these people and found them good.
http://stores.ebay.co.uk/McGill-Motorsports,
I cannot do those small boxes thing
- Leigh Ping
Posted 12 years 5 months ago #60314Yellow Peril wrote: I cannot do those small boxes thing
'Sorry, this shop does not exist.'
You can't do links either Ken. :lol:
- Yellow Peril
Posted 12 years 5 months ago #60315I haven’t lost my marbles they are in a bag somewhere
- Leigh Ping
Posted 12 years 5 months ago #60372Did you mean 'these people' Ken?Yellow Peril wrote: Hangs head in shame, going to stand in corner.......
- Yellow Peril
Posted 12 years 5 months ago #60396I haven’t lost my marbles they are in a bag somewhere
Replied by David Aiketgate on topic Re: Windscreen wiper spring clip fix.
Posted 12 years 4 months ago #66451David
- midlife martyr
Replied by midlife martyr on topic Re: Windscreen wiper spring clip fix.
Posted 12 years 4 months ago #66489Please Log in or Create an account to join the conversation.
I'd say yes ...
mine did this
The driver side wiper parked itself in the vertical position.
- Leigh Ping
Posted 12 years 4 months ago #66498Unfortunately, I already had the problem which I discovered months ago by accidentally brushing against the wiper arm causing it to drop off. :dry: Seeing how this is a 'general problem' with many of our cars, it might be worth a little test. If your wiper arm pops off with only a small amount of pressure applied to it, then it's not particularly safe, so it would be worth applying this fix for a few quid. Or, at least keeping one handy in the car.midlife martyr wrote: I normally take the view if it aint broke dont fix it but I wonder if fitting these clips before the problem occurs it would make the linkage bulletproof ?
The only guarantee is that it will always happen at the worst possible time. We were heading to our first meet in the Lake district and were literally two minutes from home when this occurred.
Attachment DSC04353.JPG not found
Fortunately, I carry some zip ties so I was able to apply the video fix below.
There are some long term fixes - clickety click and some very expensive fixes can be bought, if you wish to go that way. Whichever way you choose. It's best to be prepared. :broon:
