Engine prawn
- Diesel Destroyer
Spec is.... Er... Fair to middling
The engine will end up with independent throttle bodies.. So the alloy manifold is on just for now
- Diesel Destroyer
Scholar EVO2 block (1.9l)
Scholar forged pistons
Sump baffle
Balanced crank (entire bottom end balanced)
EN24 Flywheel
AP 'ultimate street clutch'
Light weight alternator pulley
Uprated oil pump
Uprated oil rail
Uprated water pump
New oil pick up
Hellier head (based on TF160)
633 cams.. converted to non VVC
Titan ITBs (when I find some)
Emerald ECU
Engine being re-built by Hellier with new bearings/gaskets etc (full re0build)
New perishables (coils/ plugs etc)
Air/oil cooler (not got yet)
Janspeed 4-2-1 (the larger lotus GT one)
Janspeed sports CAT
TT MK7 (number 4)
Elise oil filler caps
Vernier pulleys
Hi flow fuel filter
Modified lower engine mount and polybushed
- Diesel Destroyer
Not so much a labour of love.. as I aint done a thing... but was an expensive engine.. :omg:
Ive since decided its too nice to get dirty.. so its staying in the house
- a Guest
- Visitor
Diesel Destroyer wrote: Spec if you are really bored..
Sump baffle
EN24 Flywheel
Uprated oil pump
Uprated oil rail
Uprated water pump
New oil pick up
Emerald ECU
Janspeed sports CAT
TT MK7 (number 4)
Vernier pulleys
Hi flow fuel filter
- John and Sue
All seems normal to me!! :yesnod:
- a Guest
- Visitor
- a Guest
- Visitor
- Jack of Hearts
- Once more into the breach
- Diesel Destroyer
Divorced and broke.. Then Hellier/Scholar engine... Even more broke
- Diesel Destroyer
Jack of Hearts wrote: Come on show us the ports!
Nothing to see here... Lol
Next up is buy the 4-2-1 and the sports cat...
Oh.. Whilst I remember... The Elise parts oil pump gear DOES NOT FIT... It was that badly made it went round off centre so didn't get fitted...
Snotty e mail to them in a min
