MGF subframe bolts
MGF subframe bolts was created by Diesel Destroyer
Posted 12 years 1 month ago #93057
As I intend to replace every single nut and bolt on both my F subframes I've been looking for a break down..
Anyone know of one?
If not is there any interest in me posting my breakdowns?
Allan
Replied by David Aiketgate on topic MGF subframe bolts
Posted 12 years 1 month ago #93060
Breakdown?:broon: Absolutely! As long as you promise not to cry :P
Last Edit:12 years 1 month ago by David Aiketgate
Last edit: 12 years 1 month ago by David Aiketgate.
Replied by Diesel Destroyer on topic MGF subframe bolts
Posted 12 years 1 month ago #93085
Spheres 4 of M8x25mm per sphere
The box sections on the front subframes require 3 of M10x25mm each
Steering rack requires 2 of M8x50mm
Front wish bones require 2 of M12x100m per arm
Subframe mounts too car 10 of M8x40mm per subframe
The rear trailing arms (thin ones) require M10x60mm per arm
Rear tie bars require M12x100mm each
Main rear arm requires M12x100 each
Engine arms require 3 of M10x40mm plus M10x50mm one off plus M10x100mm 4 off..
Top alternator bolt is M10x120mm plus nyloc nut
Engine mount (belt end) requires. 3 of M10x100mm and one M10x85mm
The following user(s) said Thank You: bryan young, Johnny the Fox, west470, Splintercat, j0ris, whippet
  • Visitor
  • Visitor
Replied by a Guest on topic MGF subframe bolts
Posted 12 years 1 month ago #93089
Diesel Destroyer wrote: As I intend to replace every single nut and bolt on both my F subframes I've been looking for a break down..
Anyone know of one?
Allan
You are going to put photos and break downs of every nut and bolt you remove :-?
Replied by cjj on topic MGF subframe bolts
Posted 12 years 1 month ago #93106
It's very handy to know, because instead of paying £8 per bolt, you can walk into a nut and bolt place and pay £3 for 5 of the same spec.
  • Visitor
  • Visitor
Posted 12 years 1 month ago #93108
Or go to a supplier who does them all at trade :broon:
Posted 12 years 1 month ago #93113
Yep. That's what I do but you need the sizes.
  • Visitor
  • Visitor
Posted 12 years 1 month ago #93128
Would it not be better as a how to, rather than a thread :-?
Posted 12 years 1 month ago #93146
Might be worth it once built up.
  • Visitor
  • Visitor
Posted 12 years 1 month ago #93149
and what bolts make up the rear one.
Replied by bryan young on topic MGF subframe bolts
Posted 12 years 1 month ago #93156
I have been using Westfield fastners for stainless steel bolts and nuts, mind you i have used a lot of the ones that were "SCRAPPED" after the installation of the Tetra- pak machines. I used button head hexagon socket ones for the underbelly plate. No one wanted the spares (ss bolts and nuts) and my contractor was instructed to put them in a skip (by the barrow load :slapme: what a :slapme: waste)
Posted 12 years 1 month ago #93177
Yes good point Jan it could do with being made a sticky so if someone wanted a particular bolt they could look down the list and find it
There are 'under bonnet' bolt kits on e bay. But there could be a market for 'subframe bolt kits' too?
I'm not going stainless as they can fracture on the bits that can be higly stressed so going 12.9 zinc plated and will copper grease all of them on the thread to make removal in the future easier
The following user(s) said Thank You: freelancer
Time to create page: 0.503 seconds
