why does my mgf take ages for the heaters to warm
why does my mgf take ages for the heaters to warm was created by bluelightmgf
Posted 11 years 11 months ago #99780
:frosty: does anyone have a problem with their heaters taking 2 weeks to get warm. The car takes a lifetime to warm up. If so is there solution ???
Replied by Seal on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99783
Sounds like the heater needs bleeding or the heater control tap has packed up. The heater normally comes on stream very quickly.
Bensewell had the same problem with his a while ago.
by Seal
Replied by cjmillsnun on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99787
I have a suspicion that your thermostat may be stuck open.
Replied by jac114 on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99789
my tf does the same i have tried bleeding the system 3 times now, it does get hot but takes about 6 miles driving to do so but my mk1 is pretty much hot by the end of my road
by jac114
Replied by tim-mgf on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99790
Some people in the past have put a small hole in the thermostat to allow continual flow to protect against thermal shock when the thermostat opens. One big side effect of this is it takes longer to warm up.
I'm not saying this is a good idea, but who knows what previous owners have done?
Cars - Making me poor since 1989
by tim-mgf
Replied by bluelightmgf on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99792
If i sit in one place it will warm up quicker but if one the move its just warm at best. The temp gauge is just above 0 when on the move. as soon as i stop it starts to climb
Replied by David Aiketgate on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99793
All possible reasons above.
First thing to do is remove the ashtray! If you put your left hand in there while seated in the driver's seat, you will be able to feel the heater pipes. Bottom one in in and top is out. After running the car for 10 minutes test these pipes for heat.
If the system is working properly the bottom pipe should be almost too hot to touch and the top less hot.
If the bottom one is hot and the top one cold there is no flow through the heater matrix. This could be the valve stuck shut, or air in the matrix preventing flow.
Last Edit:11 years 11 months ago by David Aiketgate
Last edit: 11 years 11 months ago by David Aiketgate.
The following user(s) said Thank You: Gadget2466
Posted 11 years 11 months ago #99794
Let us know what you find and we can go from there.
Posted 11 years 11 months ago #99795
bluelightmgf wrote: If i sit in one place it will warm up quicker but if one the move its just warm at best. The temp gauge is just above 0 when on the move. as soon as i stop it starts to climb
That definitely sounds like thermostat.:yesnod:
It could explain some of your idling problems also.
Posted 11 years 11 months ago #99798
Bottom is really hot top is hot but not as hot as bottom.
Posted 11 years 11 months ago #99803
Is your heater blowing hot now?
Posted 11 years 11 months ago #99836
Sorry for the delay. the heater warms up when your parked but never gets really hot and as soon as i drive its back to bordering warm
