why does my mgf take ages for the heaters to warm
Replied by bluelightmgf on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99838
When i was parked and felt the pipes the gauge had gone to the second mark from the bottom and it was blowing hot air. As soon as i drive its back to warm at best
Replied by David Aiketgate on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99843
Definitely your thermostat is stuck open. Replacement required. :shrug:
Posted 11 years 11 months ago #99851
I will check out the how to and get one ordered. nightmare.
thanks David
Replied by coxy134 on topic why does my mgf take ages for the heaters to warm
Posted 11 years 11 months ago #99855
Do you have or have you fitted the remote prt kit? Mine takes much longer to warm up now.
by coxy134
Posted 11 years 11 months ago #99860
I haven't fitted one and don't believe its been done. The car was pretty basic when i bought it.
Posted 11 years 11 months ago #99865
I have the PRRT fitted also and I can't say I've noticed any change in warm up time. :nonod:
I do know when there was a surge of retro-fitting the PRRT there was a lot of units piped up incorrectly and that gave rise to heat up problems.:shrug:
The correct fitting of the pipework doesn't look logical. I have a photo somewhere.
Last Edit:11 years 10 months ago by David Aiketgate
Last edit: 11 years 10 months ago by David Aiketgate. Reason: added photo
Posted 11 years 10 months ago #100723
Got the thermostat and changed it today. car heats up nice and hot and the temp gauge is straight up to the right place. When i removed the thermostat someone had completely cut the middle of it out leaving just the housing. was a nightmare job and i nacked it on the first go. i tried to leave the pipes in which go to the left of the housing but it was far easier in the second attempt just to remove all the pipes, put the thermostat housing in an then re fit the metal pipes. 1st go took 2.5hours the second go with the pipes removed took 40 minutes including removing and putting the pipes back in. At least its done and it was well worth it.
heat heat heat yuuuuuup.
Last Edit:11 years 10 months ago by bluelightmgf
Last edit: 11 years 10 months ago by bluelightmgf.
The following user(s) said Thank You: Gadget2466, Blow-in
Replied by Blow-in on topic why does my mgf take ages for the heaters to warm
Posted 11 years 10 months ago #100733
A result! Well done - great feeling when you can fix things yourself.
Richard
by Blow-in
Posted 11 years 10 months ago #100734
Just check that you haven't had a PRRT retrofitted. They fit a cut down thermostat flange in place of the original when fitting a pressure relief remote thermostat housing. It is normally fitted between the engine and the underfloor pipes and is usually visible through the nearside rear wheel arch.
Posted 11 years 10 months ago #100742
That was the how to i used but it doesn't say or its not clear to remove the pipes completely. its a nightmare leaving them in.
Replied by Leigh Ping on topic why does my mgf take ages for the heaters to warm
Posted 11 years 10 months ago #100747
Thanks. It actually says it on one of the pics but maybe I should add it to the text as well if it'll help. Glad you fixed your problem. :broon:
Time to create page: 0.761 seconds
