MGF Wheel Nuts
Replied by David Aiketgate on topic MGF Wheel Nuts
Posted 11 years 11 months ago #103549
talkingcars wrote:
Fitment
These nuts have a 'Radius' (round shaped) seat, so are suitable for all original alloy wheels.
If you have after-market (non original) wheels check that they require Radius seat nuts. Some after-market wheels require 'Tapered' (cone shaped) seat nuts.
From what I see on the ad he is saying they may not fit after-market wheels.
However all alloy wheels ever fitted by MGRover use the same nuts, these are different to O/E spec steel wheel nuts but can be used on spare wheels, O/E spec steel wheel nuts can not be used on O/E spec alloys.
I can't see the one peice of info I was looking for in the ad, the taper should be 60'.
Specifications
Thread size: M12 x 1.5
Internal thread length: 28mm
Overall nut width: 24.5mm
Overall nut height: 34mm (inc seat)
Spanner size: 19mm (3/4 inch)
Seat type: 60° Taper (cone shaped)
Bolt material: Heat treated carbon alloy steel
Bolt finish: Bright zinc plated
Our stock code: P1
Dimensions of wheel nut M12x1.5
Last Edit:11 years 11 months ago by David Aiketgate
Last edit: 11 years 11 months ago by David Aiketgate.
Time to create page: 0.393 seconds
