Instument alloy clock rings
Replied by David Aiketgate on topic Instument alloy clock rings
Posted 11 years 10 months ago #103539
Ah, the spindle... Yes, I went through a couple of those before getting my illuminated needles in. I just bought a s/hand instrument pod and swapped the entire gauge over. It was the temp gauge I had problems with too.:lol:
Last Edit:11 years 10 months ago
by David Aiketgate
Last edit: 11 years 10 months ago by David Aiketgate.
- richandpaula
thanks for this thread - i might of changed my mind on wanting to add these now if its common and that easy to break the needles!
by richandpaula
- midlife martyr
Replied by midlife martyr on topic Instument alloy clock rings
Posted 11 years 10 months ago #103989
I have found a way to solve this problem on the temp and fuel gauge don't push the rings all the way home then the back of the red needle is above the ring
The following user(s) said Thank You: David Aiketgate, Mindy
I have a secondhand clock set winging its way to me, I did go to the local scappy and he wanted £30, which I thought was a little steep. Found one on the bay of e for £15.
I'd certainly do the mod again, it was my own ham fisted action that caused the problem, although the alloy rings are not as good a fit as expected. It does make a nice difference with them on, esp with the blue leds lighting the alloy rings up.
by Mindy
i Fitted a set to my MGF ,perfect fit .
Removed when selling the MGf and tried to fit to the TF pah same problem as you mate
by paulsmgf
I wish I'd been online when you first posted this Mindy .....
The solution is simple - file the inner curvature of the alloy ring by a fraction of a millimetre where the needle base would rub, prior to fitting.
It's the easiest way.
by mogatrons
Time to create page: 0.473 seconds
