Cubby Hole attempt
Replied by richandpaula on topic Cubby Hole attempt
Posted 11 years 7 months ago #113983
http://forums.mg-rover.org/showthread.php?t=309779
Hope we don't mind a bit of cross pollination from other forums?
Replied by bensewell on topic Cubby Hole attempt
Posted 11 years 7 months ago #113985
I will get the dremmel out.
Replied by David Aiketgate on topic Cubby Hole attempt
Posted 11 years 7 months ago #113987
richandpaula wrote: http://forums.mg-rover.org/showthread.php?t=309779
Haha Rich!. That is Kara's post (MGchic) the originator of this forum!:lol:
Posted 11 years 7 months ago #113988
Didn't think you'd mind that one.
Posted 11 years 7 months ago #113990
And here's Adamelphick's original how to: ;)
Replied by Fil6909 on topic Cubby Hole attempt
Posted 5 years 4 months ago #190891
Hi , great upgrade ... can you tell me how the back of the funny is formed / blanked off please .cheers.. rover 25 box or mgzr?
by Fil6909
Replied by talkingcars on topic Cubby Hole attempt
Posted 5 years 4 months ago #190912
Fil6909 wrote: Rover 25 box or MGZR?
Basically the same car with different badging.
Posted 5 years 4 months ago #190948
Thanks , (auto text wrote 'funny' - could have been worse 😶 !) , meant to be cubby.. was wondering how the back is formed ?
by Fil6909
Replied by Fisher on topic Cubby Hole attempt
Posted 5 years 1 month ago #191754
HI All
I know this thread is some 6 years old, but I have just received a MGZR Dash Cubby and looking at fitting it as others have done in the past. Tried to find a good How-To but some are so bad because the pics are missing, and therefore it is difficult to understand what to do without them.
So, have airbag cover off and the first thing is the large securing brackets for the airbag. Looking at the set-up it is not a simple solution to just cut of the airbag brackets as there is a second piggy-backed bracket which holds the power-steering ecu!
Questions has anyone cut the brackets away? Did it help in fitting the Cubby. Did you move the power-steering ecu? how?
This would be a nice upgrade if I could get rid of the brackets.
by Fisher
Posted 5 years 1 month ago #191756
Hi I used a passenger side Cubby Box off a Rover 25, I've and I removed the metal frame removing the three bolts behind the dashboard, never came across the ECU ,and never tackled the framing for steering to accommodate left-hand drive.
Some of the pictures are quite old( if they are still available )however my posting is only a month or two back
(fil 6909) and I have included a couple of pictures here, almost the end result. Message me back if you want some further information I'm pleased with the result although it was quite exacting not quite done yet , but I propose to fix from the side edge with two screws into the the small reveal on the airbag aperture
by Fil6909
Posted 5 years 1 month ago #191757
Hi Fil6909
Thanks for the update it certainly helps. Will be taking the upgrade(!) today so will report back, what I found.
To confirm I certainly have the power-steering ECU fitting piggy-backed under the steering brackets so will not be able to remove the brackets.
by Fisher
Posted 5 years 1 month ago #191758
Hi Fil6909
Finished cubby!
As I said mine has the powersteering ECU so could not cut off steering brackets, which meant I had to shorten the cubby (I still think it would still be a little tight)
Removed approx 30mmm from the back of the cubby. The cubby now fits flush with the top of the dash but then widens to the bottom by about 10mm.
I suspect I would have to cut into the existing dash to be able to seat the botton lower opening of the cubby to fit flush with the dash.
At this stage I am not willing to do that so short-term will live with it. But does not look out of place.
To finish, I glued some carpet (has some from old liner when I bought a new boot linert) over the open inner section I cut out.
Finally, temporarily fixed with lage blobs of silicon to the steeing brackets.
Fitted rubber mat. Looks good.
Will consider triming for a better fit once I have got used to the new cubby.
by Fisher
Time to create page: 0.705 seconds
