Posted 6 years 10 months ago #182957
Fourbears wrote: .......Got the roof partially open and heard a loud crack. Knew exactly what it was and thought "Why didn't I unzip it?"! Doh!
Before my glass window I used to start the roof opening, nip to the back of the car to check it wasn't creased and then gently opened the roof, even in -2. Maybe I was lucky.
Replied by Fourbears on topic Wocha bin doin on your MG this week then?
Posted 6 years 10 months ago #182963
The one I cracked was thicker plastic and less flexible than the original type. Apparently these were made about 10 years ago and supplied with a different zip (so I had to change the zip carrier too) so perhaps I was not so lucky. I will check in future though!
Replied by John and Sue on topic Wocha bin doin on your MG this week then?
Posted 6 years 10 months ago #182974
In between household jobs I replaced the dip headlamps with Osram Nightbreakers as recommended by
David A. I'd previously updated with Halfords very own upgrades which didn't seem that much different tbh. Can't road test at the moment as I've had the regulation couple of DIY tinnies. Open paint can, open beer can.:broon: I'll report when we've next been out in t'dark.
Whilst under the bonnet I checked the voltage at the lamp terminal block: a couple of mV under battery voltage so all good. Cable resistance an all dat ting. If significantly lower would be an indication of bad earth etc. Also gave the headlamp glass a T cut: removes any bloom.
Actually one of the least painless jobs on a TF: if only all repairs/replacements were as painless!
Replied by gooseholla on topic Wocha bin doin on your MG this week then?
Posted 6 years 10 months ago #183094
Not so much working on the car but made an mg thing out of a bit of wood I had which was too lovely to bin and didn’t know what to do with it. That changed when I was surfing eBay and saw an old mg badge for sale. Turned out alright I think!
Posted 6 years 10 months ago #183113
Nice work gooseholla.
Not done much on ours tbh, too 'kin cold. One thing I did do was address a small parch of hood green mould just behind the drivers window. I've found over the years that a decent quality upholstery cleaner, one of those with a scrubby thing on the end of the can works well: spray, leave a few mins, scrub, leave, wipe, gone! I've found that this works better for a whole hood clean than proper soft top cleaner.
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 6 years 10 months ago #183146
Remap booked in for the Friends Round London run! K-Maps will be attending the event and offering their services.
Now I will be looking forward to the event even more now!
Sundance
Posted 6 years 10 months ago #183214
In the last week I have replaced the rear zip carrier and screen, cleaned the spade connector on the starter motor and finally got all four speeds on the heater fan again. Been meaning to do that for a while!
Posted 6 years 10 months ago #183216
Went to local scrappy and collected a pair of headlight lenses, chap at the counter wasn't happy because I'd "broken" the headlights until I pointed out they are clip on, he mumbled that I should have taken the whole light. I would have done but I don't need them. #projectorheadlightproject
Posted 6 years 9 months ago #183387
Making good use of my day off today...
New brake servo bracing bracket fitted...
Powder coated battery clamp fitted too .....
And my new side scoops put on....
Sundance
Posted 6 years 9 months ago #183392
Dang those scoops look good.
I sprayed some water proofing liquid on my hood. Exciting!!
John
The following user(s) said Thank You: SundanceUK
Replied by graham1 on topic Wocha bin doin on your MG this week then?
Posted 6 years 9 months ago #183395
where did you buy the scoops? want some
by graham1
Posted 6 years 9 months ago #183396
One of the guys on here sold them.
I know there were some similar for sale on the FRL facebook page, with and without the slats.
Maybe some slatless ones on ebay too.
Sundance
Time to create page: 0.720 seconds
