Replied by minimax on topic Wocha bin doin on your MG this week then?
Posted 2 years 10 months ago #197991Being a trained radio engineer, I know how important it is to calculate the exact length of the wire to 27 decimal places so I pulled a length out of the scrap bin that was about 18" long, attached it to the end of the yellow wire and routed it upwards, trapping the end under the centre vent and tucking the end in so it didn't show. Result? an illuminated oil temperature gauge in a place where I can read it and a reliable thirty foot locking range. Tore the garage apart and failed to find my USB charger but it will turn up as I have ordered a new one.
Told Madam that I was assembling her Christmas present which I did last week so I'm back in the good books.
Posted 2 years 10 months ago #198001The original radio cassette has long wave but no auxiliary input so I downloaded the manual for it and went snooping around the circuit with some success. I can cut a couple of PCB tracks and solder a couple of wires to swap them them over. That means that I could put a cassette in and enable the CD preamp inputs which should allow me to add an auxiliary input without recourse to FM transmitters or plug in cassette adaptors. I need to establish whether the tape end detector will auto reverse the deck at random or whether I shall need to find a way of fooling it that the deck has a cassette installed to use the input or ejected to use the radio so It is embryonic right now although it will allow the use of the original set if I can get it to work. I can buy a much better one off marketplace for a tenner, of course, but that is not the point!
Posted 2 years 10 months ago #198015Please Log in or Create an account to join the conversation.
Posted 2 years 10 months ago #198017
Posted 2 years 10 months ago #198018Please Log in or Create an account to join the conversation.
Posted 2 years 10 months ago #198021
- Kiwi2001MGF
- Apprentice MGer
Replied by Kiwi2001MGF on topic Wocha bin doin on your MG this week then?
Posted 2 years 10 months ago #198113Checked with the Pscan and no cam sensor fault, so very happy with that.
An oil and filter change while I had the engine cover off as it was due.
Ready for more happy miles.
Posted 2 years 10 months ago #198116Please Log in or Create an account to join the conversation.
Replied by Gavin207 on topic Wocha bin doin on your MG this week then?
Posted 2 years 10 months ago #198124Bought a cheap oil change kit from toolstation for £10 - good value as long as you don't expect too much for this price 😀 made it much easier to fill the gearbox.
My top tip - when replacing any ball joints if you can afford them buy those with a torx or allen socket in the end of the taper - makes dismantling later much easier as you can stop the taper rotating whilst undoing the nut. Otherwise if the taper starts turning with the nut the only solution can be to cut through the taper stem.
Posted 2 years 10 months ago #198125Changed my leaking gearbox oil seal today - very pleasant in the warm sunshine. Surprised how different the replacement oil seal was from the original.
The oil seals may vary in design with different manufacturers.....not unusual. So long as the inside dia, outside dia and the thickness are the same.
As for the ball joints, a rattle gun usually gets the nuts undone without the stem turning...........Shock and awe!
another method is to keep pressure on the ball joint whilst undoing the nut.
Either of the above is much preferred to cutting
Posted 2 years 10 months ago #198152Managed to find a front and a rear displacer so I can gas a pair up and swap them for the ones in the car which in turn can be swapped, saving downtime and providing a bit of insurance should one of them not be up to much.
Posted 2 years 10 months ago #198200My top tip - when replacing any ball joints if you can afford them buy those with a torx or allen socket in the end of the taper - makes dismantling later much easier as you can stop the taper rotating whilst undoing the nut. Otherwise if the taper starts turning with the nut the only solution can be to cut through the taper stem.
and if you can't find a cap fill the recess with grease or copper slip to stop it filling up with gunge.
