Posted 3 years 3 months ago #196520
Today I fitted a new blower resistor.
I found one on AliExpress for about $13 so thought it was worth a shot.
It's nice to have 4 speeds on the fan.
Well done, got a link?
Replied by deepfat on topic Wocha bin doin on your MG this week then?
Posted 3 years 3 months ago #196526
Today I replaced the cigar lighter with a twin port USB outlet that also gives the battery voltage, why are easy jobs so hard. I now know the plastic tunnel does not properly align with the metal frame it is bonded to resulting in a hard struggle to even "POP" the ashtray out and the same with the lighter, I had to relieve the lighter hole with a small grindstone to get the new one in!!
I have also today bought on line what appears from the photo's to be a binnacle in good condition with all mountings intact, time (or the postman) will tell, these are apparently a bugger to fit, so if easy is hard a bugger must be %*?@£!++++
Gawd Help Me
by deepfat
Posted 3 years 3 months ago #196527
New Zealand so it's mid winter Yep you need 4 speeds
by deepfat
Replied by Kiwi2001MGF on topic Wocha bin doin on your MG this week then?
Posted 3 years 3 months ago #196578
It's the low speed that didn't work which is needed as the heater is for UK winter and cooks me
Never feel cold in my MGF .
Posted 3 years 3 months ago #196579
Sorry no, I just hunted MGF parts.
Posted 3 years 3 months ago #196584
Oh, ok, the only one I see on Aliexpress is a cheap one.
  • psymon
  • 2001 MGF 1.8 in MNX
Posted 3 years 2 months ago #196867
Treated the rusty areas underneath and fitted new underfloor pipes, Made up and fitted new brake pipes on the front, rears are ready to go in. Swapped out loom for a Later TF one ( All though now I have an ABS ECU Connector and nought to connect it to) , Interior mostly refitted , and loads of little things.
by psymon
The following user(s) said Thank You: Roverlike
Replied by TwistedPuppet on topic Wocha bin doin on your MG this week then?
Posted 3 years 2 months ago #196891
Fitted low antifreeze level alarm.
Started undersealing body now subframes are done.
New battery.
Checked lights to make sure I had not left something unplugged and will be MOTing soon.
While checking brake lights noticed high level one was dead. Traced the wiring from loom after reading posts here and found somebody previously had resoldered wires and sealed. Checked redone connections with a multimeter and all fine.
Only then did I check the actual high level brake light unit. The two wires for it on the loom side ended in a connector, connected to nothing. THe wiring and connecter from the light unit are not there!!! I assume this is for it to pass previous MOT's, hope it still does. It has been out before judging by the glued together crack on the right side end of light.
Kicked a tyre.
Posted 3 years 2 months ago #196892
Well I'm totally disgusted at myself as yesterday I reversed my TF into a small post :bat: ! What a dingbat!
Ontop of that I was planning to go to MGF n TF go North on Sunday . I don't think I'll be winning any prizes for looks .
Replied by neilpinleeds on topic Wocha bin doin on your MG this week then?
Posted 3 years 2 months ago #196966
Tour of Western Scotland. 705 miles over six days, car ran like a dream. Fills two and three were E10.
  • psymon
Posted 3 years 2 months ago #197001
Front ARB cleaned up and refitted with new bushes.
by psymon
Posted 3 years 2 months ago #197013
diagnosed the problem with my speedo, the bottom cable has snapped 1 inch from the gearbox, now to make a new cable.
Time to create page: 1.111 seconds
