Posted 2 years 6 months ago #199040
Ah an imperial measurement, now we understand each other!
Replied by minimax on topic Wocha bin doin on your MG this week then?
Posted 2 years 6 months ago #199041
The TF rack arrived yesterday, as did the DAB antenna so the car now has a phone and digital radio. Today, rear speakers. I could do the rack today and even the coolant pipes but I will be moving tools up to Gordon's today as the next job is making his car fit for the Le Mans trip and it is LEAKING WATER!
by minimax
Posted 2 years 6 months ago #199046
It’ll be interesting to hear your thoughts on the tf steering rack, initially I was a little ambivalent to the change whilst pondering the grazed knuckles, cricked neck & Volterol back. Manoeuvring, particularly in reverse required more recalculation than I would have though, obviously I am now hefted to it to such an extent that the last f I drove felt strange.
Posted 2 years 6 months ago #199071
Before Gordon's car went to the great b road in the sky, it gave up its mark 2 airbag and the rear tub seal which made an immediate difference to my car. The door rattles just went away. The clutch bleeder arrived so that is on tomorrow's list, together with either fitting a new rack or stripping out the interior for the red leather seats I have coming.
by minimax
Posted 2 years 6 months ago #199082
Clutch bled. A litre of fluid pumped through and little improvement so I checked the operating arm which was completely free . The pivot was tight so I took the clevis pin out and lubed it all up. Slightly smoother action but no real over centre feel and a lower pedal than I like. Time to look at the master cylinder clevis and examine it for ovality. First though, I really must finish the low coolant alarm.
by minimax
Posted 2 years 6 months ago #199089
So I did. Routed the three wires from the sensor to the buzzer and fuse box through  the grommet under the hood well carpet on the driver's side. I ran the wiring under the carpet and into the fuse box, picking up for the time being on the fuse I put in for the mirrors. Drained off 250 ml and off it went. Good. What I saw in Gordon's engine convinced me that it isn't an optional extra. Tomorrow I might go off for a 600 mile jaunt, once I have removed the door cards.
by minimax
Posted 2 years 6 months ago #199111
The gearchange is much improved and there is the hint of an over centre action on the clutch. I have learned how to select the required track on the stereo and have worked out how to get three seats and four  door cards into an MGF.
by minimax
Posted 2 years 5 months ago #199143
They do indeed but the fitting costs added in meant that Asda do the best deal and they get them fitted by my local tyre fitter. I am going to be a heretic and put 195 section on the front rather than 185 as I think it will give me a balance I will like better.
It's touch and go for me - Asda are £10 more for fitted than Demon Tweeks unfitted but the man over the road from me will fit them for £10 a tyre and he is available without having to book.
Posted 2 years 5 months ago #199193
Changed the gearbox oil. Collected Gordon's F from Southend. Removed NSF hub from same ready for a wheel bearing change. Needs a little work here and there but fundamentally sound. A week to go to ready both cars for Le Mans.
by minimax
Posted 2 years 5 months ago #199202
Removed the clutch damper from mine. Gordon's got a new wheel bearing, a drop of oil on a sticky hood catch, a tyrap in the mirror bracket, the hand brake tightened and elastic straps on the hood. He is a very happy Gordon as he finally has an F.
by minimax
Posted 2 years 5 months ago #199222
A very busy day. Full scrub on Grrdy's interior which was pretty filthy and once that had been done, the ride height was investigated. The rather high passenger's side was at over 500 PSI so I reduced it to something more sensible and the ride height came into spec. "Try it now." When he came back ten minutes later, he was a very happy fellow. I took it around the block. It was, as I had predicted, VERY much better. I oiled the hood frame which made a difference, changed the clocks over and set to work on tidying the body. There was a bit of filling and touching in around the vents and some awful bodged repainting simply wiped off with thinners and touched in a bit more sympathetically. A good mopping and it looks just fine. It handles fairly well and all is now ready for the Sarthe.
Last Edit:2 years 5 months ago by minimax
Last edit: 2 years 5 months ago by minimax.
Replied by Bluemoon on topic Wocha bin doin on your MG this week then?
Posted 2 years 5 months ago #199241
Been a bit of an up and down week for me
Spent the week on and off removing what was an abortion of wiring used for the front spots (previous owner used house flex, and separate non standard switch under the dash) when turned on the rear spot warning light on dash would illuminate?
Removed all the wiring and put in bin, purchased loom with relay and switch included from Ebay and ran wiring as per their instructions, couldn't get the lights to work, checked out everything with meter which seemed fine? Finally ran fused feed direct from battery to relay and proved live side of wiring was OK did same with earth and they finally worked (turned out I had a poor earth behind the dash to the new relay :-?
All working now :clap: but manage to kill the battery draining it with lights on etc. (it was 7 Years old) fortunately new Bosch battery was given to me by the previous owner which is now fitted and holds charge.
As a final kick in the groin the engine management light decided to illuminate :omg: so off I went to buy a cheap code reader. Cleared the code (flat battery was culprit)
Taking a rest from working on her and taking her out this weekend :drive:
Last Edit:2 years 5 months ago by Bluemoon
Last edit: 2 years 5 months ago by Bluemoon. Reason: missed a word
Time to create page: 0.737 seconds
