The essential guide for new chums
  • Online Topic Author
The essential guide for new chums was created by Cobber
Posted 8 years 4 months ago #170287
Here is a place to put tips for both new & prospective new owners of the MG F and TF.
I have a MGF so my recommendations relate to that model range.
Please feel free to add to the list, and I hope the owners of TF models also add to this list. (Please state if your tip applies to the F or TF)
For the F, I consider the fitment of a low coolant alarm is essential for minimising the risk of head gasket problems.
I would also fit the tail light covers to the back of the tail lights in the boot, I had a great many tail light problems until I fitted these.
Replied by Scruffygit on topic Re:The essential guide for new chums
Posted 8 years 4 months ago #170288
I have 97 mk1 F vvc. She's done 92000ish miles. Re-bushing and new gas filled shocks (kyb's) transformed the drive and banished lots of Clonks and bangs! Well worth the outlay and time spent. Highly recommended.
Sent from my DAGGER DG550 using Tapatalk
Replied by Airportable on topic Re:The essential guide for new chums
Posted 8 years 4 months ago #170299
As an F driver I concur with Cobber on the coolant sensor & rear light covers & I would interlink the washer circuit with the wipe, it's one wire a a bit of a fiddle. Another is to fit the alarm passive coil that fits around the ignition barrel from a later car, again its a bit of wiring to the alarm module & it prevents having to reset the alarm when you stop for a few minutes. It's hardly a hardship, but it bugged me. Keep a diary & costings, but don't let your wife / husband / partner know about it.
Replied by cairnsys on topic Re:The essential guide for new chums
Posted 8 years 4 months ago #170301
Can you expand on how you did this? Which wires are interlinked and where?
I'm sure others will be interested and I for one have not seen this anywhere else.
Thanks. :broon:
Replied by David Aiketgate on topic Re:The essential guide for new chums
Posted 8 years 4 months ago #170303
Don't fit Suplex... :rant:
Replied by talkingcars on topic Re:The essential guide for new chums
Posted 8 years 4 months ago #170304
Airportable wrote: As an F driver I concur with Cobber on the coolant sensor & rear light covers & I would interlink the washer circuit with the wipe, it's one wire a a bit of a fiddle. Another is to fit the alarm passive coil that fits around the ignition barrel from a later car, again its a bit of wiring to the alarm module & it prevents having to reset the alarm when you stop for a few minutes. It's hardly a hardship, but it bugged me. Keep a diary & costings, but don't let your wife / husband / partner know about it.
Can you do how to's for the wash/wipe and the passive coil?
Posted 8 years 4 months ago #170320
I will do a “how to” on both mod's as soon as I get back from holiday, however I am away for a month. These mod's are applicable to cars with the Lucas 5AS system, as yet I haven't come to grips with the Pektron unit. The inspiration for the wiper mod came from the Rover 200 wiring diagram, the F has a lot in common here. So from the washer switch positive (light green / black tracer) you take a wire to C62-23 on the multi function unit. I can't put my hands on my original notes & as I'm supposed to be packing for holiday, I'm being grumbled at so I'll sort that out when I'm back.
The passive coil connects to pins 11 & 12 on the alarm unit; the coils were fitted to MY2k onwards but my guess is that any AR cars from that period will have them. They simply unclip from the ignition barrel & pop onto the vacant spot on the recipient. You will need to extend the wires.
Another thought, which flows out of the R200 diagram piece, is know your car bits & what is used elsewhere. Bits for the “K” engine crop up all over Rover & Land Rover stuff. There are more Land Rover specialists than MG, so when I needed an engine sensor urgently I went to the nearest LR bods to pick one up & it was cheaper than an MG specialist.
One last bit before I get slaughtered; shorten the gear stick & tighten up your gear linkage. Do make sure you have a gear knob that will fit after or one that has been modified. Tighten up the gear stick yoke & change the scroll pin on the selector shaft (buy some new boots & change those when your underneath.)
Right I'm off.
The following user(s) said Thank You: Leigh Ping, Andy Lawrence, cairnsys
Replied by Airportable on topic The essential guide for new chums
Posted 8 years 4 months ago #170323
Make sure you can get your spare out, the screw thread behind the knob rusts solid & you don't want to find that out when it's dark & raining.
Replied by mgtfbluestreak on topic The essential guide for new chums
Posted 8 years 4 months ago #170358
Dont place the keys in the boot and shut it.... :slapme:
The following user(s) said Thank You: FrenchTF
Time to create page: 0.533 seconds
