Exhaust sensor post cat
Hi all my exhaust is rotten and really needs replacing its the later one with the bend on the cat and the 2nd sensor, I have been given a trophy bb and decat pipe the older type without the sensor which I'm considering fitting as a stop gap until I have the funds for a full stainless system, I know it will fit and obviously the sensor can't be fitted so as a test I disconnected the sensor in the engine bay near the ecu to test the car and it's not bringing any faults up which is good. Has anyone done this or had any experience of fitting decats etc the car actually seems to drive a bit better as well with the sensor unplugged.
Cheers Nick
Cheers Nick
by Nick71
The one after the car is just to monitor emissions to test cat is working and will not make ecu changes.
As for ecu light I can't comment.
Sent from my GT-I9505 using Tapatalk
by MC_Bob
Well swapped them out should be good for a few more thousand miles don't know why I took it off ????
by Nick71
The need for the post cat sensor can be removed during a remap.
by talkingcars
Or you could fit a MIL eliminator.
http://www.the-t-bar.com/forum/22-cjj-s-guides/86933-fitting-a-mil-eliminator
I have changed my cat and back box but where oh where does the post cat sensor cable go to?
I need to unplug it!
Thanks for the post!
by Frank
The MIL eliminator is no more than a 1m ohm resistor grafted into the black wire & a 1uf tant across the grey & black, positive to the loom side of the resistor. I found this whilst reserching another topic & such haven't tried it.
by Airportable
Looking from rear of car, it connects just to the left of the ECU bracket near the top of the engine bay.
Best bet is to "fiddle " the wire and look for movement near the ECU
Very fiddly to get new cable up there, so drop a small wire from the top, to pull it back up after replacing.
by G0RSQ
The following user(s) said Thank You: David Aiketgate, Frank
Time to create page: 0.521 seconds
