Key fob repair
My '96 VVC continues to give sterling service, its approaching 30,000 miles in my ownership now (in 3 years) and I wouldn't be without it.
It has, however, developed an odd fault.
I have two key fobs for it, and with new batteries and some soldering (as per the guides in this magnificent forum), both worked perfectly for over 2 years. Recently, one of the fobs won’t lock the car. It will unlock it with no issue, and the immobiliser is switched off by pressing the unlock button, so I can get the car started ok. Just that lock button doesn’t work. (the 2nd fob is fine in all respects, meaning that the ‘car-side’ of the system must be ok).
So my question is what’s wrong with it? My guess would be that the ‘lock’ button (micro switch) has failed. I see that fob repair kits are available on ebay for a fiver or so, which contains new micro switches, is it easy enough to strip the fob and replace just one micro switch? It strikes me that the fob PCB itself must be working for the car to unlock and work with the immobiliser, so this repair would be a lot cheaper than a whole new replacement fob plus re-programming costs?
:yesnod:
- BruceTF135
If so, they aren't particularly difficult to replace in a pcb (depending on your soldering skills, obviously. You should be able to check the operation of the suspect switch, in-situ, with a multimeter.
If this is what you need, they are cheap from ebay in a variety of sizes or, if you ask me nicely, I'll send you one FOC.
Bruce.
I'll measure them and drop you line, Sir.
- BruceTF135
The switches I talked about are 6mm square and come with various length buttons. Mine are a total of 7mm from the base of the switch to the top of the button. They look about the same as yours. The legs will need to be cut and bent to fit the solder pads but that's not difficult.
If you really aren't confident, I'd have a go for you but I'd make no promises...
Hmm, love a challenge!
Well, I say I, I actually mean I took the fob and the new switch (courtesy of the link elsewhere in the thread) to the bloke who fixes mobile phones in town.
He has a tiny soldering iron, a magnifying glass and oodles of patience. He charged me £7 to fit the switch and it now works as it should.
- BruceTF135
TaffMGF wrote: Never one to rush into something, I eventually got around to this.
Haha! That really is taking your time! I know that, if you have the soldering skills, it's not particularly difficult but £7? Total bargain!!!
:drive:
In my defence, I hadn't used the car that much and it has kind-of slipped down the lost of jobs t do on the fleet.
A fine-tipped soldering iron was going to set me back £10 plus some solder. He had a bit of a struggle with it as well, apparently. I paid with a tenner and told him to keep the change but he wouldn't have it. He's gone straight onto the good contacts list.
