pscan.eu 041C up date .
- sworkscooper
Thanks for that , I may give him a call. Really frustrating , as today pscan gave me a supposedly good EKA but could I get it to work ............ Grrrrr . Nope .
Cheers again, John.
sworkscooper wrote: Hi Robin .
Cheers again, John.
That's really strange because the EKA you read off the BCU must surely be the correct one
Robin
- sworkscooper
John
I don't mean to be rude but are you sure you used the code correctly? The correct process is in the Owners Manual.
Robin
- sworkscooper
John
- John and Sue
Best fit for pscan.eu would be Premier Stella Can.europe strength.
- sworkscooper
Big dumping of snow has put this on hold . :rant:sworkscooper wrote: I've just been reading it again and I am sure I've done it right . Tomorrow is another day and I will attack it with renewed enthusiasm . The ZR I owned also didn't have a code until I asked the dealer for it , I had no problem with that code . Ho hum !
John
- sworkscooper
John
- sworkscooper
The final word on my dilemma with the EKA and this comes from the very knowledgeable, Paul at Technozen . He says the likely cause of me pulling what little hair I have left out is that the car's door lock is not sending a viable signal from the door lock micro switches to the BCU . There are three of these switches on the drivers door lock . One sends signals that the door lock is being unlocked , one for a signal for locked and the third one that the lock is vertical in the handle . If the Pektron BCU doesn't receive a clear voltage while the EKA is in the process of being done it won't understand what is going on and therefore will override the third number in the sequence and lock the door . It would seem that I have two faults ..... one is the fob that I already knew about and the second is possible corrosion in the multi plug on the inside of the door that feeds the lock switches or indeed the switches on the lock itself . Paul has told me if it is indeed the lock micro switches that they are not serviceable so, it will need a new lock mechanism .
So I will now relax in the knowledge that it is just an MG thing so , fix John , fix it !
Thanks for all the input guy's ( and girls ) and sorry if I have been boring you all .
John.
Ps Now I think at some point I mentioned the pub ! :pop:
- John and Sue
I do however hark back to simpler times when the man/machine interface problem consisted of... The ign terminal has dropped off the coil/the teeth have stripped off the starter bendix/I've locked me keys in the car... Again/I left my car at the pub and walked home. Can't recall which pub....
- sworkscooper
John
