No more spinning gear knob and bluetooth :-)
- richardgr88
No more spinning gear knob and bluetooth :-) was created by richardgr88
Posted 6 years 8 months ago #184426
For a while now the gear stick on my TF just used to keep spinning around - I got used to it but the wife wasn't that keen so I decided to take action.
Quite pleased with the result. Used my new drill to drill a hole in the what I'm guessing is aluminium, then tapped the hole and inserted an M4 bolt which I cut with a grinding disc on the dremmel. Small step for man but a great step for the spinning gear knob
I have also added an Anker SoundSync Bluetooth adapter - I brought it for a previous car but never used it. it seems to work quite well. Plugged into a USB port in the arm rest, cables running up the centre and plugs into the 3.5mm of the Sony headunit. Now have bluetooth calling and music.
Next step in and out car thermometer and we'll really be in the 21st century
by richardgr88
The following user(s) said Thank You: David Aiketgate, talkingcars
Replied by davidgv1 on topic No more spinning gear knob and bluetooth :-)
Posted 6 years 8 months ago #184428
Hi Richard,
I have viewed your repair of the spinning gear knob, it may well be an idea to remove the screw and replace it with a 4mm grub screw, maybe 5mm in length. This will serve the same purpose, but will look a lot neater, especially if you can set it flush.
Cheers
Cheers
by davidgv1
- richardgr88
Replied by richardgr88 on topic No more spinning gear knob and bluetooth :-)
Posted 6 years 8 months ago #184429
Already got some on the way in the post It was weird this morning, kinda got used to the spinning.
by richardgr88
Replied by Airportable on topic No more spinning gear knob and bluetooth :-)
Posted 6 years 8 months ago #184431
Might I recommend a second or even a third grub screw, a single one will not have enough traction under normal use; you will be forever tightening it up. As the thread form is in aluminium it won't take many nips up before it strips.Voice of experience.
by Airportable
- richardgr88
Posted 6 years 8 months ago #184432
I have got a pack of 5 on the way so one or two more wouldn't be an issue - also means I get to play with my nifty tap tool again and new drill. I could always drill a very shallow hole in the shaft itself so the grub screw has somewhere to locate if needs be
by richardgr88
Posted 6 years 8 months ago #184436
Hi Richard
If you can manage to drill into the shaft, deep enough to take a thread, then tap through the gear knob and shaft in one go and apply the grub screw, then this should do the job. ( the grub screw straddled across the 2 items)
As Airportable suggests, it will be a better repair if aided with a second screw.
Cheers
Cheers
by davidgv1
- John and Sue
Replied by John and Sue on topic No more spinning gear knob and bluetooth :-)
Posted 6 years 8 months ago #184446
Grub screw 101: for a quick fix, cut a set screw to the required length, cut a slot with a junior hacksaw or needle file, dress with a file or emery and hey. Also presto.
by John and Sue
Replied by stephenj on topic No more spinning gear knob and bluetooth :-)
Posted 6 years 8 months ago #184448
I used some loctite. I holds well for everyday use. if you need to remove the knob then a bit of force will do it.
by stephenj
Time to create page: 0.543 seconds
