BRAKE LINES.
BRAKE LINES. was created by stevew
Posted 6 years 8 months ago #184442
Evening all.
I've not been on the bar much of late although I always check in. I just need to know if it's a difficult job to replace the complete brake line system on a TF. I've already bought all parts and tools required and practiced how to make a double flare.
I'm quite competent with tools but this is a task I've never done before and just need a bit of encouragement and guidance if possible. My TF already has braided hoses fitted and I will be fitting a brake servo bracket. (Does it make a difference??).
Is their anything I should be aware of before I set myself to the task.
:beer: :beer: Steve.
by stevew
Replied by David Aiketgate on topic BRAKE LINES.
Posted 6 years 8 months ago #184445
Clive's How to
That should give you a good guide.
Yes, the servo brace does make a notable difference. Especially to the 'feel' of the pedal
The following user(s) said Thank You: stevew
Replied by sworkscooper on topic BRAKE LINES.
Posted 6 years 8 months ago #184447
Hi . As with any job that you are not familiar with you are going to feel a bit apprehensive. Just take your time . The only problem I could forsee is the bending of the tubing can be challenging and if you are a bit overzealous you can end up kinking the tube . You have already said that you have practiced making the flares so as long as you compare the flared end you remove with the one you replace it with you should be fine .
Like David said the pedal bracket does give the pedal a firmer feel as I fitted one a couple of years back and felt it was worth the effort .
John
Replied by graham1 on topic BRAKE LINES.
Posted 6 years 8 months ago #184449
easy job, just make sure you don't break the plastic brake holders, as they are really hard to get hold of, it took me 4 hours to change the lot, but put new flexy hoses on, as it is easier while you have everything off, it can be a little tricky getting around the cooling pipes, I did mine while my cooling pipes where off as I put stainless steel ones on after I fitted the brake pipes, it would be better though if there where two of you, but shouldent be too hard, I did mine on the ramps with the extention peices so it would not catch the rear or front bumpers, good luck.
by graham1
Replied by stevew on topic BRAKE LINES.
Posted 6 years 8 months ago #184456
Thanks Graham.
Works will commence in the next week or so. I did fit some Goodrich stainless steel braided hoses a few years back.
Thanks again for the advice and no doubt I'll be back again to pick your brains if that's OK.
:beer: :beer: Steve
by stevew
Posted 6 years 8 months ago #184457
your welcome :broon:
by graham1
Replied by Airportable on topic BRAKE LINES.
Posted 6 years 8 months ago #184473
Can I catch up on this one, I've been away? Graham, you imply that you changed the whole system, can I ask if you made your own pipes from scratch or whether you bought a kit & is your car ABS. This is a job I'll need to address shortly so I'm in the planning stage, therefore if you made your own, which flaring tool do you have, a picture would be useful. I know you said it took you four hours & was easy, even working on ramps, but could you give us more details? You might be a lot more bendy than I & as I'm rapidly approaching a new hip I don't want to embank on a four hour job only to have to give up after six with an immobile car. Thanks Mike.
Posted 6 years 8 months ago #184475
the brake master cylinder bracket makes a huge difference to the braking, I know I fitted one, though you do need the fingers of a Chinese watchmaker , this is well worth doing.:broon:
Last Edit:6 years 8 months ago by graham1
Last edit: 6 years 8 months ago by talkingcars.
Posted 6 years 8 months ago #184476
Thanks Graham, both may cars have ABS, however that knot of pipework is in good condition & as it's the f which needs looking at, all the front pipework is accessible under the bonnet. Having spent some time in a very cold garage earlier I find that the bit that was of concern is the only bit which is of concern. A shivery run around with the brake spanner tells me that it's not going to be a fight so I'll have a friend recreate the dicky one & bang it on when the Arctic withdraws to the Arctic. Tah Mike.
Posted 6 years 8 months ago #184479
glad to know you can sort it out and you have someone to help you:broon: :clap:
by graham1
Posted 6 years 7 months ago #184905
Hi guys.
Jobs going well so far, not had much time lately with work and that. As I'm going along I'm doing other jobs as well. As I've got the braking system drained I could do with some new bleed screws for the calipers.
Can we get stainless steel ones for the front ap calipers and the standard rear calipers?
by stevew
Time to create page: 1.455 seconds
