central locking
central locking was created by graham1
Posted 6 years 6 months ago #185171
got a clicking noise like a machine gun coming from my door locks, any help, please thanks
by graham1
Replied by talkingcars on topic central locking
Posted 6 years 6 months ago #185173
Probably a failed micro switch in the drivers door lock.
Replied by John and Sue on topic central locking
Posted 6 years 6 months ago #185174
Had this on the passenger side. Bought a s/h lock assembly off eBay buy it the noo for 17 quid. Sorted. Locking silence. I took the old one to bits out of curiosity: as TC says, probably the micro switch, but not really user serviceable unless you're a micro- gynaecologist. One of dem t'ings full of springs, switches, plastic levers and ball bearings etc. All of which ping past your ear 'oles as the last screws release.
Can offer help/ guidance, as will others, if you go down the replacement route. One hour job. Keep us informed.
Replied by David Aiketgate on topic central locking
Posted 6 years 6 months ago #185176
Be careful not to deadlock the car, as faulty locks have a liking for failing in the locked position. Means forcing the doorcard off to fix.
Replied by vdv on topic central locking
Posted 6 years 6 months ago #185177
Change it before it locks you out. when i bought mine the passenger one made the same noise.
by vdv
Replied by graham1 on topic central locking
Posted 6 years 6 months ago #185178
hi, can you give me a clue as to what to do and how to do it, would be grateful for any advice and help :-?
by graham1
Replied by BruceTF135 on topic central locking
Posted 6 years 6 months ago #185179
graham1 wrote: hi, can you give me a clue as to what to do and how to do it, would be grateful for any advice and help :-?
There are a few how to pieces here:
CJJ's door lock mechanism replacement
Kara's Door Handle - How to remove/replace
Let us know how you get on...
Replied by g4wam on topic central locking
Posted 6 years 6 months ago #185185
Hi-you didn't say if the car was an MGF or TF ,although the locking mechs are the same on both models they are activated differently.
If both locks are making a whirring or rattling sound this is not likely to be a door lock fault on both sides .
If the car is a TF with the oval shaped fobs you could have a SCU controller relay fault .
Could you supply more detailed info about your problem
regards
Mike
by g4wam
Posted 6 years 6 months ago #185189
hi it is a 2003 tf
by graham1
Posted 6 years 6 months ago #185191
As above, you need to let us know whether it's one or both. :yesnod:
Posted 6 years 6 months ago #185195
to be honest I will change them both that way I will be sure I have fixed them.
by graham1
Posted 6 years 6 months ago #185196
thanks but there is no way it can lock me out always garaged with the roof nicely tucked away, that way if all goes cocks up I just climb in, the alarm is working spot on so if I try and get in when it is activated the whole world can hear it.
by graham1
Time to create page: 0.536 seconds
