Fuel trim bank
Fuel trim bank was created by Flyingoysters
Posted 6 years 6 months ago #185404
Hi, I keep getting EML light on and the code read is fuel trim bank 1 fault? Any common issues to cause this please?
MGTF 2004
Cheers
Chris
Last Edit:6 years 6 months ago by Flyingoysters
Last edit: 6 years 6 months ago by Flyingoysters.
Replied by sworkscooper on topic Fuel trim bank
Posted 6 years 6 months ago #185405
This could be one of those quirky ones . I think I remember something like the pre cat oxy sensor being faulty was the cause on my ZR many moons ago . I don't think it has any bearing on the amount of fuel in the tank ie low fuel .
John
Replied by g7nbp on topic Fuel trim bank
Posted 6 years 6 months ago #185408
This one used to crop up occasionally on ex-wifes TF. I never tracked it down to anything specific, and the fault just went away.
by g7nbp
Posted 6 years 6 months ago #185409
https://www.yourmechanic.com/article/p0170-obd-ii-trouble-code-fuel-trim-malfunction-bank-1-by-andrew-quinn might shed some light. I have a feeling problem on ex-wifes TF was down to some dodgy fuel that clogged the filter for a while and eventually cleared.
by g7nbp
Replied by Flyingoysters on topic Fuel trim bank
Posted 6 years 6 months ago #185410
Thanks for replies
So is this a case of try a component and see if it current, or is there any better way of checking/elimination?
Cheers
Chris
Posted 6 years 6 months ago #185411
Yup, possibly so. Essentially it could be something transitory like what I assume was a fuel filter clog on wifeys car, but equally it could be MAP sensor fail or a split hose, or even a lambda problem. Ultimately the error is telling you the fuel mix is wrong, but not off it's too rich or lean.
In the first instance I would clear the fault code, pop a squirt of injector cleaner into the petrol and give it a good run at temperature. This might be enough to clear the problem.
If not, and if no other sensors are showing error or out of range readings, the next simple check is to unscrew the spark plugs. Often a lean / rich problem can be diagnosed simply by the appearance of the plugs.
Once it's established if it's a lean or rich mix it's possible to narrow down problems.
by g7nbp
Posted 6 years 6 months ago #185412
Okay thanks for getting reply, I will try some injector cleaner first
Don't notice any difference of heavy fuel usage
I have changed plugs a while ago , the ones I took out looked normal TBH
Cheers
Chris
Posted 6 years 6 months ago #185413
Have you changed fuel filter? It's something many people overlook. I forget what the recommended service interval is, but the chances are on a car as old as a TF it's probably due if it's not been done.
by g7nbp
Posted 6 years 6 months ago #185414
Thanks again
Yeah unchanged all filters, plugs and oil at same time
Replaced under floor coolant pipes and anti freeze at same time!!
It's been coming on sincemi bought it coming up 2 years ago, lived with it for long enough, just wanting to sorting now!
Cheers
Chris
Replied by David Aiketgate on topic Fuel trim bank
Posted 6 years 6 months ago #185432
If you get an obd2 code reader(either blue tooth or wifi depending on type of smartphone) and download the Torque app(free) you will be able to monitor your fuel trims in real time.
This will tell you whether it is long term or short term fuel trim that is out of whack. Also whether the fuel trim is too high (Most probably)or too low.
From there you can then narrow down where the problem is by googling fuel trim problems. There are a number of good web pages that delve into this issue.
Fuel trim is how much fuel the ecu adds or subtracts from the standard amount to get the air fuel ratio to 14.7 to I. Shows as a percentage on torque. Long term and short term trim are basically what they sound like. Short term is an instantaneous figure. Long term is time average.
You get a fault if the ecu can't get the ratio correct. It attempts to correct the fuel by altering the injector pulse times. So the fault could be as simple as blocked air or fuel filter or injector issues. Or induction leaks or fuel leaks.
Hah! Should have clicked on the link above and saved myself a lot of typing.:doh:
Last Edit:6 years 6 months ago by David Aiketgate
Last edit: 6 years 6 months ago by David Aiketgate.
Posted 6 years 6 months ago #185453
Thanks very much David
I will give this a try
Cheers
Chris
Replied by croxalldog on topic Fuel trim bank
Posted 6 years 6 months ago #185463
I had this problem with my stepspeed. Missfire reported and fuel trim fault. Changed absolutly everthing nothing cleared it for more than a week. Out of desparation I reverted to a garage. The engine had 2 faults, a slight water leak into pot 1 that caused a really bad tickover when cold but cleared when the engine heated up expanded and sealed the leak. Secondly the camshaft timing belt was one notch out. Someone had removed the cam belt and not checked the timeing marks on replacement. Only 200 miles down the road but it appears to have sorted the problem. OBDs will not find this but they will show wierd fuel trim readings.
The following user(s) said Thank You: g7nbp
